LOW REV HESITATION
westworld
  Z3 coupe 3.0i
LOW REV HESITATION
Post by westworld » Sun 15 Mar, 2015 22:28
my 3.0 auto at 1500 - 2000 rpm and accelerate nothing happens its like pulling a truck then kicks down 2 gears and all is ok , any ideas welcome, ive heard coils or spark plugs or cam sensor ???
Re: LOW REV HESITATION
Post by Del » Sun 15 Mar, 2015 23:02
A coil problem would tend to give a permanent misfire and a failed sensor would normally cause a warning light on the instrument cluster. Unless you know the service history, I would start with simple service items like plugs & air filter - both these items get left in for ages these days and if a sequential main dealer service regime was disrupted, these items can often get overlooked and left in far too long.
Gordon13
Post by Gordon13 » Mon 16 Mar, 2015 07:16
Cam sensor is entierly possible. Failure only
logs a ' silent' fault code so no warning lights.
Get the codes read at a garage or some one that has carsoft or inpa.
There may be a member near you who can help, whereabouts are you??
westworld
  Z3 coupe 3.0i
Post by westworld » Mon 16 Mar, 2015 20:14
thanx for help & advice ,based in Lincolnshire
Gordon13
Post by Gordon13 » Mon 16 Mar, 2015 20:22
Ah im in devon so cant do it for you.
try putting up a post asking if a member near you can run a diag.
