Steering wheel judder?
Warrior
Post by Warrior » Mon 16 Mar, 2015 22:55
I'm sure there's something on here already but I can't locate the thread?
What I thought was a poor road surface was causing the steering wheel to judder. I'd checked to see if any weights had fallen off the wheels and checked the nuts as I'd experienced the same effect some weeks before.
Again this evening the same again. Happens at mid to high speed but only not all the time.
Any suggestions, bushes or bearings maybe?
Re: Steering wheel judder?
Post by bertiejaffa » Mon 16 Mar, 2015 23:11
Mine was due to a front brake caliper sticking slightly - easy to spot, jack the front end up and spin the wheels, should be nice and free.
EDIT got a replacement one from euro car parts, £70 ish plus £25 ish of that back when I gave them the old one: £50 fix, 1 hours work max
Post by gookah » Mon 16 Mar, 2015 23:43
after a drive see if one wheel is hotter than the other (don't touch the discs though :D ) the hot one is a sticky caliper
Post by Del » Tue 17 Mar, 2015 11:13
I agree with the two posts above - I would put money on a sticking calliper. Had the same happen to both my fronts, within weeks of each other, last year. I opted for "remanufactured callipers".
Warrior
Post by Warrior » Tue 17 Mar, 2015 13:38
So not something a bit of WD40 would sort?
Post by bertiejaffa » Tue 17 Mar, 2015 16:24
Warrior wrote:So not something a bit of WD40 would sort?
Not usually the best remedy on the brakes lol
Post by Southernboy » Wed 18 Mar, 2015 12:58
go for a drive to heat up the brakes a bit or until you feel the juddering - go home, get the car up on jack stands st the front, start the motor (in neutral) and press the brake pedal - with the motor still running, get out and turn each front wheel by hand and feel for any "catching" as you turn them. You can feel for a warmer rim which may indicate which wheel may have a faulty caliper. Best attend to it sooner vs later - if it is a binding calliper, you could overheat the brake disc and end up warping it.
Warrior
Post by Warrior » Thu 19 Mar, 2015 18:40
Cheers...I now know what i'm doing this weekend :)
TR4man
  Z4 coupe 3.0si
Post by TR4man » Thu 19 Mar, 2015 20:35
I've had this happen twice in the three years or so that I've had my Zed - sticking calliper each time.
Post by Del » Thu 19 Mar, 2015 21:03
I think it was always quite a common problem on the E36 and E36/7 (Z3) ranges - particularly as they get older. The hot wheel is the absolute confirmation and the smell of burning paint (if you have painted the callipers :D ). I bought "remanufactured" ones from GSF which from memory were about £65 each (after exchange). They are stamped BMW/ATE as the originals and are rumoured to be either completely "remanufactured" or "as new" surplus BMW stock.
Dead easy to change, the calliper hanger bracket stays in place and it's just the centre calliper that is renewed which involves just removing the two, lightly torqued "slider bolts". If your slider bolts are anything like mine, around 3/4 of an inch close to the thread is coated in carbonised brake dust which took some time to clean off with a scotch pad before replacing.
TWO
Post by TWO » Thu 19 Mar, 2015 21:33
Funny you should mention this.......I went to Halfords today to see if there was any product I could spray on the calipers to avoid/prevent the them from binding......I got the usual "can I help you sir?"
The young assistant recommended a full spray with WD40. When I asked him if WD40 was safe; as its a lubricant and surely not wise, he advised that "you drive at 30 mph with the brakes gently applied to clear the pads"...........needless to say I ignored his advise :head:
Post by bertiejaffa » Fri 20 Mar, 2015 10:56
Jesus! That's frightening!!! Suddenly I'm quite happy that there are a fair few miles between Manchester and Chelmsford.... Although if he takes his own advise and applies his brakes down south he might end up in Birmingham!
