Z3 - alarmed whilst the hood is down !!!!!!!
ARoosterinaRoadster
Post by ARoosterinaRoadster » Sun 28 Jun, 2015 14:55
Hi to you all out there. I have looked into the knowledge base but cannot find anything that points to an answer.
I believe that I have read somewhere that the car is alarmed when the hood is dropped insomuch as "Low-Lifes" deciding to exercise their light fingers would trigger the spacial sensors BUT the other day I decided to investigate the probability and mine will not/did not alarm the cabin area of the car.
The Owner Handbook/Manual appears not to cover the eventuallity of hood down security.
What say you !!!!!!!!!!!!!!
Fender2004
Re: Z3 - alarmed whilst the hood is down !!!!!!!
Post by Fender2004 » Sun 28 Jun, 2015 16:22
On my car there are two sencers one at the top left and top right of the windscreen, so the alarm covers the cab area. The little Red led on your dash is a switch if you push it in it turns them off, and if the switch is in the out position they are active with the alarm.
ARoosterinaRoadster
Post by ARoosterinaRoadster » Sun 28 Jun, 2015 17:41
Fender2004 wrote:On my car there are two sencers one at the top left and top right of the windscreen, so the alarm covers the cab area. The little Red led on your dash is a switch if you push it in it turns them off, and if the switch is in the out position they are active with the alarm.
Hi Fender2004. Thank you,I will go out there and investigate after evening meal.
ARoosterinaRoadster
Post by ARoosterinaRoadster » Sun 28 Jun, 2015 19:08
Hi again Fender2004. Well now then. Where I believe that you have an LED - at the front central part of the flat curve of the dashboard - I only have a flat disc that looks suspiciously like a blanking disc and there are no Sensors at the top Left & Right of the windscreen.
The absence of the neccesary is confirmed when sitting in the car - Hood up - car alarmed and arms waving around and total silence.
My car is a 2000 (W) reg. Build date December 1999 2.0 Auto.
littlefeller
Post by littlefeller » Sun 28 Jun, 2015 20:29
I have motion sensors too, 98 build. don't know if they work though as I have never set the alarm :shock: its not really a good idea to mess around with alarms with immobilisers on second hand cars, some will disagree but I speak from experience (not mine but a work mate and his second hand bike). unless you tested these devices before you actually brought the car, something I always forget to do :dunce: sound as though someone removed yours unless they were optional when new, sure someone here will know.
Post by BladeRunner919 » Sun 28 Jun, 2015 21:16
littlefeller wrote:I have motion sensors too, 98 build. don't know if they work though as I have never set the alarm :shock: its not really a good idea to mess around with alarms with immobilisers on second hand cars, some will disagree but I speak from experience
The alarm and immobiliser are different systems on the Z3, so you won't really cause any problems by messing about with the alarm. And, unless you have an EWS delete, you can't avoid using the immobiliser.
Post by Robert T » Sun 28 Jun, 2015 21:35
The early alarm (separate fob type) has a pushable LED and the movement sensors are visible at the top of the windscreen pillars. Pushing the button disables the movement sensors.
The later alarm (buttons on the key) just has an LED light and the sensors are hidden in the footwells. Locking the car twice with the remote disables the movement and tilt sensors.
On neither alarm is there anything that detects whether the roof is up or down. The alarm should work with the roof down and the way to test it is to put something on the seat and then reach in to try to grab it. There is a delay period before the movement sensors are enabled, so you need to wait until the LED drops to a steady flash after locking the car.
As mentioned above, the immobiliser is entirely independent of the alarm system and will function even if the car is only locked with the key (i.e. alarm not set). On the later alarm, the immobiliser can be used to disarm the alarm should the remote battery go flat - the immobiliser chip is read via an inductive loop and does not need a battery in the key - simply put the key in the ignition and turn to position II.
Fender2004
Post by Fender2004 » Sun 28 Jun, 2015 21:50
Thanks for the info Robert you never stop learning. :rtm:
ARoosterinaRoadster
Post by ARoosterinaRoadster » Sun 28 Jun, 2015 22:54
Robert T wrote:The early alarm (separate fob type) has a pushable LED and the movement sensors are visible at the top of the windscreen pillars. Pushing the button disables the movement sensors.
Hi Robert. Thank you. I have just been out again to the car and there are no LED's on the dashboard - albeit there is one on the front of the radio which flashers when the key is withdrawn and the car is either left unlocked or is locked with the key fob or the key.
I will check-out the hood down -alarm situation in the next day or so when I am away from our ultra quiet Cul-de-Sac of pensioners bungalows.
If it is anything like the siren on my Volvo V70 SE Geartronic there could be a rush on ambulances for the heart attacks that could follow !!!!!!!!!!!!!
Post by Robert T » Mon 29 Jun, 2015 00:29
The alarm LED on mine (later alarm) is between the seats on the rear switch panel. It looks like a switch blank with a slightly raised area in the center.
littlefeller
Post by littlefeller » Mon 29 Jun, 2015 08:35
how does the immobiliser actually work, I never use my brick fobs only the key, so if I lock with the key (no fob) then alarm not on but immobiliser is on. so is my key coded to the ecu? or does it use an immobiliser that doesn't communicate with the ecu? I have 3 ignition keys, 2 black and one grey along with I think is a small alarm key, all keys excluding alarm key work in the ignition. I also have 2 fobs (brick type) both have flat battery's and would need to be linked again I would presume, I quite often lean into my open top and pick things up off the passenger seat with no alarm going off but as im not using the fobs it now makes sense. the guy I brought the z from also didn't use the fobs (the batteries hadn't been changed for years), I was a little suspicious of his motives for not trying them. so if I play around with the alarm im not going to get stranded like my friend did, not only did he get stranded he also needed a re-wire to loop out both the alarm and the immobiliser, something that isn't that simple as there designed in such a way as to make this difficult if not impossible.
ARoosterinaRoadster
Post by ARoosterinaRoadster » Mon 29 Jun, 2015 09:41
Robert T wrote:The alarm LED on mine (later alarm) is between the seats on the rear switch panel. It looks like a switch blank with a slightly raised area in the center.
Hi again Robert. Ah ha said the blind person. Yes,indeed there is one as you say. I had truly not seen that before as I am not really looking in that direction when in the car and until now have not had the need to look through the windscreen with the car locked and the alarm set.
I will investigate the hood-down scenario in the next day or so.
Jonco
Post by Jonco » Mon 29 Jun, 2015 09:48
little feller wrote:.............. I also have 2 fobs (brick type) both have flat battery's and would need to be linked again I would presume........
It is almost definite that you will have to re-programme fobs if batteries have been flat for a length of time. This may be of help https://zroadster.org/articles/3g-ews-r ... amming.24/
By just using the door keys you are only operating the central locking not any part of the alarm system. The extra small key you refer to is for turning the siren on and off in the engine compartment. HTH
Post by BladeRunner919 » Mon 29 Jun, 2015 09:57
littlefeller wrote: so is my key coded to the ecu?
Yes. There's a transponder in the key that is detected by an antenna around the ignition switch.
ARoosterinaRoadster
Post by ARoosterinaRoadster » Mon 29 Jun, 2015 10:23
Hi Jonco. Well another little bit of essential detail learned - when I got my Z3 from the dealer that had taken it in as a PX against an SLK !!!!!!!! It had no little (Siren) key.
I guess that it is a trip to my local BMW dealer/parts department suitably equipped with a box of Paracetamol !!!!!!!!!!!!! and a stiff Whiskey (Irish) not Whisky (Scotch).
Jonco
Post by Jonco » Mon 29 Jun, 2015 11:09
Hi - the info I gave was for little feller's question on the house brick type. You appear to have a later version so the programming of keys is done differently by a sequence of holding down buttons on key fob - I confess I don't know much about that type but I'm sure somebody will come up with something - there is a `how to' article in the knowledge base.
ARoosterinaRoadster
Post by ARoosterinaRoadster » Mon 29 Jun, 2015 15:06
Hi - the info I gave was for little feller's question on the house brick type. You appear to have a later version so the programming of keys is done differently by a sequence of holding down buttons on key fob - I confess I don't know much about that type but I'm sure somebody will come up with something - there is a `how to' article in the knowledge base.[/quote]
Hi again Jonco. Yes,I was vaguely aware of that and currently don't appear to have issues with my Key Fob albeit I - as yet - haven't heard my Siren (if one is fitted). Having looked under the bonnet and into the engine bay I cannot see one or anything that would suggest that there is a Siren somewhere else and linked with wires from a key position.
bazza1966
Post by bazza1966 » Mon 29 Jun, 2015 17:43
Hi Fender thanks for info did not realize the LED was a button to turn the alarm sensors off :dunce: I have not been using the alarm with hood down as the flipping thing kept going off :head:
tried your little trick hey presto alarm works fine again TY :roll:
Bazza (East Dorset)
Post by Robert T » Mon 29 Jun, 2015 18:14
The later alarm does not have a key for the siren, as it can be reset by putting the key in the ignition as I described above. The siren is located directly below the fusebox.
The immobiliser chip in the key is coded with a unique cyclic code and if I remember correctly there are just 8 possible "keys" for each car. The car can be programmed to disallow keys if they are lost (I've never done it before you ask). The immobiliser works in the same way for both alarm types, but the newer alarm has the added feature of disarming via the immobiliser. The immobiliser works by reading the code from the key and this allows the car to be started. After the car is turned off, the immobiliser will remain disarmed for a period of time (something around the 20-30 second mark). If you were to get a spare key cut, you would find that you can start the car with it if you have used an original key and then immediately try the new key, however if you were to try the new key on its own, it would not start the car, as the immobiliser would have armed itself. You can read about this in an old thread on here where someone had a spare key cut and then couldn't start the car with it. A cheapest complete replacement key (with chip, but without remote) is about £60 from the dealer and is known as a grey service key.
I believe that the later alarm is the more reliable of the two with the roof down.
littlefeller
Post by littlefeller » Mon 29 Jun, 2015 19:19
thanks folks, think that covers it. opened one of my fobs (the only one with a battery in) only to find that that too is flat :lol: will get another and try it out.
Fender2004
Post by Fender2004 » Mon 29 Jun, 2015 20:30
Glad you got it sorted :D
Users browsing this forum: Baidu [Spider], Google [Bot] and 4 guests
