Hi, does anyone know anyone who can delete the immobiliser funtion from my ECU for me? Its a 2.8 twin vanos and I'm really struggling.
Here's the scenario should anyone have any other suggestions:
Bought as a 1.9 (2001), replaced the engine with a 2.8 (1998 twin vanos) which I bought with EWS/DME/Key, etc.
All worked fine and drove for about 6 months.
Then I moved house and lost the key! Now I can't get a replacment key becuase I've changed the locks, and the immobiliser code doesn't match the VIN.
I've bought an ebay ecu, but it came with an EWS for a 3 series - the plugs are different and they have different functions so I don't think I can rewire.
Leaving me with two options I believe - source a full set of EWS/DME/Chip and replace all, or have the immob function deleted.
All getting a bit stressy as I'm meant to be doing a road trip to Dubrovnik in it in 5 weeks for a wedding!!
Anyone have any suggestions...
Immobiliser removal
Re: Immobiliser removal
Geez, you couldn't make this story up! I feel for you and have to say Hertz or Easyjet for £74. I can only offer my best wishes.
No, its a really bad collection of events!!
I can't believe it's so hard to find someone who can just programme the immobiliser out of the ECU though!
http://www.porterbility.co.uk/Files/PDF/e36z3_01.pdf
p.197/198 shows the EWS III for a Z3.
Pin 14 on p.198 goes to Pin 33 on p.83 [Engine Control Module (DME)].
Pin 5 on p.198 goes to Pin 17 on p.83
I would investigate these by probing the wires on a car that you know is good. If the wires are 0v when the ignition is off and 12v when the ignition is on, then the EWS can be by-passed and the wires can be supplied with a fused 12v. If they are (as I suspect) signal wires, I think you are stuffed without help from someone who can recode your ECUs.
The starter immobilisation looks easy to rectify by bridging pins 7 & 8 of the EWS module.
Have fun - and have a fire extinguisher handy .
The ch no will be on the dme and also the ews module. Order a key to match, job done
Its not possible to order a key to match an engine BMW tell me, only a chassis number and the engine was swapped! Possibly BMW being awkward but I got fed up of trying with them
Anyway, I'm going to go down the route of EWS deletion, I've found a guy here that does it should anyone need it:
http://www.ebay.co.uk/itm/BMW-EWS-3-imm ... 25a95ac4bf
the VIN number of the car, your engine comes from is written on the DME of the engine.
So if it is possible to order a key just by providing the VIN number go for it. I think it is the easier option.
I never spotted that! They asked for the V5 last time, but I'll give it a go, thanks
I've just re-read your OP.
If you have used the donor EWS and the donor DME, you will need the donor V5 to get a new key from BMW.
I would go down the EWS delete route and install a personal immobilizer.
Is that some kind of tazer connected to the steering wheel?pingu wrote:... and install a personal immobilizer.
