Tyres
Gordon13
Tyres
Post by Gordon13 » Sun 13 Sep, 2015 19:03
In danger of raising on old topic here but the front end feels a little vague and there is a certain amount of tramlining.
Suspension is all good, new lower arm rear bushes, tracking has been checked - these two thing made a marked improvement but not perfect.
so attention has turned to the tyres. Front are Yokohama and probably in excess of 8 years old, but no signs of deterioration. Rears are Pirelli and six years old.
all were fitted before I bought the car.
My feeling is the its the fronts at fault, and I have read that the Z's can be sensitive to different manufacturers, so are Yokohama's in the 'bad' group and if so what's the best replacement ?
Re: Tyres
Post by BladeRunner919 » Sun 13 Sep, 2015 19:47
I think anything over 5 years old should be considered as needing replacement. I think Falkens are the most common recommendation.
littlefeller
Re: Tyres
Post by littlefeller » Tue 15 Sep, 2015 19:27
what size tyres? original wheels?
just noticed the pic on your sig, what offset are your wheels? I had a set of those with the incorrect offset, they tram lined real bad
Brian4
Re: Tyres
Post by Brian4 » Tue 15 Sep, 2015 20:04
Drop links for the front make a difference as well. I am told the cars run better on Assymetrical tyres.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
Gordon13
Re: Tyres
Post by Gordon13 » Tue 15 Sep, 2015 20:21
littlefeller wrote:what size tyres? original wheels?
To the best of my knowledge they are the original set up.
style18. 8 1/2 j with 245/40/17 on the rear and 7 1/2 j with 225/45/17 on the front.
according to the hand book and the tyre pressure chart on the B post this is a normal setup.
Gordon13
Re: Tyres
Post by Gordon13 » Tue 15 Sep, 2015 20:25
Brian4 wrote:Drop links for the front make a difference as well. I am told the cars run better on Assymetrical tyres.
interesting, the yokohama's are directional, not asymmetrical, so there maybe a clue there.
stevie_a
Re: Tyres
Post by stevie_a » Wed 16 Sep, 2015 07:17
X2 For Falkens, made a big difference to my car
Mike Fishwick
Re: Tyres
Post by Mike Fishwick » Wed 16 Sep, 2015 09:10
I have been using Falkens (in seventeen-inch sizes with staggered wheels) for fifteen years on my 2.8, in FK 451, 452, and currently 453 forms, and have no complaints. I prefer 2.5 bar all round, and get about 30k from the fronts, with 20 k from the rears.
Re: Tyres
Post by TitanTim » Wed 16 Sep, 2015 11:30
Just to flip the coin I had Falkens 452s on the Zed and it didn't thank me for it, however the fronts were 225/40 on a 8.5" rim. Handling was mediocure at best and tramlined quite bad at times depending on the camber of the road. I swapped the wheels out from the ACS 8.5x18s front and rear to 8x18s all round fitted with Vredestein Quadrac 3 all seasons 225/40 front and rear and the car handles and rides much nicer and banished all tramlining. It was probably more down to the front tyres being very slightly stetched on the rim. Personally I would spend a tad more and go Michelins or Continentals if an everyday runner.
Flight
Re: Tyres
Post by Flight » Wed 16 Sep, 2015 11:59
My 3.0i is on 16" wheels, and at one time "tramlined" pretty badly. However I could not accept that new tyres could possibly be the cause. I put it down to body flexing. So I fitted a front cross brace but apart from a slight reduction in scuttle shake there was no improvement in tramlining. I then made and fitted a rear brace, again with little improvement. A pair of side braces were made and fitted and "Hey Ho" no more tramlining. In my case my supposition appeared to correct, lack of body stiffness. I am now quite happy with the handling, and as a side effect my drive train clunk is slightly reduced, so it would appear that the rear axle changed position between acceleration and over run. However it is still annoying and will be cured this coming winter.
Flight
littlefeller
Re: Tyres
Post by littlefeller » Wed 16 Sep, 2015 17:39
mine tamed badly so i swapped the 225 for narrower 205, the transformation was amazing, im back on wider tyres now but the offsets are correct, its back again but not as bad.
Bonzo
Re: Tyres
Post by Bonzo » Wed 16 Sep, 2015 21:59
Zelda tramlined quite a bit with Avon ZV5's on the rears and Michelins on the front. Changed the fronts to ZV5s to match the rears, Complete cure. Steady as a rock! :D 8J 17inch Alpina wheels.
Hope you find a fix!
Bonzo.
