window
Re: window
The best cure is to take the door card off and clean and lube the runners. I got some silicone spray, wound the window down and sprayed down the front and rear of the window which got it running freely for quite some time.
A comprehensive article on doing it properly is here in the knowledgebase. Good luck
http://www.zroadster.net/forum/viewtopi ... 18&t=11888
Re: window
Also check the fixing bolt at the bottom of the rear window guide channel.
It has a habit of working loose and that causes the window to be slightly out of alignment.
