Please advise:
My indicator always works when I signal left. But when indicating right, sometimes it works and sometimes it does not. When it does not work - the hazard lights also don't work. (When not working it also does not make the "clicking" sound)
I assume it's a bad contact somewhere - is it in the stalk or high resistance somewhere else (fuse/relay/bulb before death??).
I recently replaced the hazard switch - so it's not that.
Erratic Indicator - Sorted
Re: Erratic Indicator - Sorted
Well - simple this time.
It was contacts on the Hazard/Flasher Relay. Touched it and it started working properly
Removed it and sanded all contacts with fine sand paper. Happy camper.
For pics an reference - http://www.ronstultz.com/knowledge/Docu ... Signal.htm
