fuel cap
fuel cap
Post by peter2b » Sat 26 Dec, 2015 22:04
when I filled up the other day I found water behind the filler cap there is a black lining around the fuel pipe holding some water is that normal or should it drain away(it had been raining hard)
alec.m
Re: fuel cap
Post by alec.m » Sat 26 Dec, 2015 22:33
There`s a drain pipe in there that can get blocked. A thin piece of wire pushed down should clear it.
l3ggy
Re: fuel cap
Post by l3ggy » Sun 27 Dec, 2015 08:16
alec.m wrote:There`s a drain pipe in there that can get blocked. A thin piece of wire pushed down should clear it.
I have the same. Thanks for reply.
Do you where all are the drain pipes located throughout the Z3?
Re: fuel cap
Post by peter2b » Sun 27 Dec, 2015 10:09
ta happy new year
leach62
Re: fuel cap
Post by leach62 » Sun 27 Dec, 2015 12:14
Dead Centre below the filler, if you get as much water out with a sponge it should become apparent if you run your finger over it.
Jim
Re: fuel cap
Post by peter2b » Sun 27 Dec, 2015 12:18
found it poked some wire down all clear now :) ,cheers
alec.m
Re: fuel cap
Post by alec.m » Sun 27 Dec, 2015 18:57
Glad you`re both sorted. :cheers
