boot gas struts
boot gas struts
my zed's boot is getting a bit heavy to lift so I need to replace the struts, only thing is the number on my struts is ******077455 but looking on ebay there doesn't seem to list parts by that number for a zed, only ones for a M3, any o e know what the part number I need
Re: boot gas struts
cheers Brian H just what I was needing
Re: boot gas struts
Typically the M has a different strut 51242497679, not found on the gas strut site
Re: boot gas struts
These guys will build you a set for a reasonable price http://www.strutsdirect.co.uk/, I bought a pair from them for my last Z although since then the website has changed somewhat.Gazza wrote:Typically the M has a different strut 51242497679, not found on the gas strut site
Maybe worth a call?
Re: boot gas struts
I got mine from ebay - let me have a look at my history.
EDIT: Bought from an ebay shop called tshopabs http://www.ebay.co.uk/usr/tshopabs (item: 131433221999 - BMW Z3 1995-2003 Tailgate Boot Struts Gas Springs Lifters x2 SET)
I know it says Z3 - but I fitted these to my M and they are perfect
EDITX2 - Link to the exact item from that seller: http://www.ebay.co.uk/itm/BMW-Z3-1995-2 ... hbadypq8AA
Re: boot gas struts
I can confirm that the RealOEM/BMWFans list the gas strut as a different part number for the ///M. The boot lid is essentially the same but for the numberplate and boot badge placement, however it looks like it is heavier because of this and consequently the ///M part is rated at 650N instead of 580N. As suggested, the non-///M part will likely fit, but the lower rating means that it won't provide as much assistance.
Re: boot gas struts
Checked the link and they show 680N so I ordered a set
Re: boot gas struts
Glad you got some - I have to admit the difference in mine now is amazing - 1st time I opened the boot after fitting them it nearly knocked me out
Re: boot gas struts
It;s like lifting a bag of cement at the moment
Re: boot gas struts
Every Z3 driver should inspect these once in a while or even better, exchange them on time! When they get older the plastic balljoints can break. And usually they break when closing the trunk. If you are unlucky the broken gas strut will move itself between boot-lid and chassis when you slam your boot lid closed with major chance for paint damage or even worse.
Re: boot gas struts
Just ordered a pair on fleabay, £21-50 inc postage to Spain!
Re: boot gas struts
fitted mine tonight when i took the the old ones off found 1 was totally duf the other I could just push the piston end in a bit new ones pops the boot lid up 1/2 way then lifts till its fully open
Re: boot gas struts
Fitted mine today, better than before but I still have to lift the boot halfway before the new struts take over.
Re: boot gas struts
Got my replacement ones for the coupe from SGS engineering .
Really pleased with them.
