Jacking up front
Lancsbob
Jacking up front
Post by Lancsbob »
Is there any place you can jack up front using single central trolly jack?
2002 2.2
Bob
Re: Jacking up front
Post by Southernboy »
Not that I have ever found satisfactory... I also have a trolley jack and it's always been a PITA jacking the front... end up using the side jacking points..
Post by bertiejaffa »
Ive followed the arm that the wheels are on and used that before now - dont know the name of it but someone will
Post by c_w »
Might be the front subframe, but that is quite far under. I jsut use the jacking points and the wishbone "ears" to put axle stands under.
Lancsbob
Post by Lancsbob »
The problem is that iv'e got a narrow garage & want to change the
engine oil plus other things out of the weather.
Cheers Bob
Brian4
Post by Brian4 »
Drive it onto some wood planks. I have a plastic drain can about the same size as a 10l water container and this fits under on it's side when on two pieces of 6x2.
like this
http://www.eurocarparts.com/ecp/c/Audi_ ... &0&cc5_147
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
Post by Gazza »
Good old fashioned car ramps £23.15
http://www.ebay.co.uk/itm/PAIR-OF-2-TON ... xy-gBSChl7
c_w wrote:Might be the front subframe, but that is quite far under. I jsut use the jacking points and the wishbone "ears" to put axle stands under.
Sounds about right... It's rock solid and works perfectly... I do have to drive it onto planks first though to get the jacks under with it being lowered
jonzee
Post by jonzee »
Or buy a Pela oil pump,Fantastic bit of kit and dead easy to use
corky
Post by corky »
Hi if you are buying car ramps you might want to add on a pair of ramp extentions . The z's are low and could catch the front spoiler. And to catch the oil I use an old plastic oil can with the side cut out easy
Hope this helps
regards corky
