I assume the loop in the front of the radiator is the power steering cooler mine looks like its seen better days, is it much of a job to change as i had one go on my saab and was left with no power steering...
whats your view on this...?
power steering cooler pipe
Re: power steering cooler pipe
I believe the consensus is if it works, isn't leaking and just looks nasty it's better just to rub it down and rust proof/paint it. I don't think it's a difficult job to change (I might be wrong). The bigger problem is finding a decent one second-hand or the expense of buying a brand new one - £80-£120 depending on who you get it from. I believe it's part number 32411093638 for all models, all ages.handsomejackuk wrote:I assume the loop in the front of the radiator is the power steering cooler mine looks like its seen better days, is it much of a job to change as i had one go on my saab and was left with no power steering...
Its not a big job to replace it.
If you are planning on doing the job, have a look at the two hoses that connect to the steering rack by the steering wheel junction. They use banjo bolts to connect to the rack. These pipes have metal sections and tend to rust out with pin holes and let you down expectantly. Especially the return hose between the rack and the cooler as the metal part run in front of the rack and is in the direct path of any water, mud or salt being flung around under the car.
i dont really want to go pulling it about i did notice loads of big pieces flaking off when i was inspecting it, hopefully it will last a few months before i need to go changing it... I just wondered if its an all in one job, or if just the front section could be replaced...?
The big square piece is pretty much just what you see before it goes into rubber hoses.handsomejackuk wrote:i dont really want to go pulling it about i did notice loads of big pieces flaking off when i was inspecting it, hopefully it will last a few months before i need to go changing it... I just wondered if its an all in one job, or if just the front section could be replaced...?
If it's just surface corrosion I doubt very much it will fail any time soon. The majority of Z3s have the same issue unless someone has gone out their way to remedy it.
If you do want to clean it up it's easy enough to take off it's mounts and swing down for attention.
Unless it's really badly corroded, clean it up and paint it with a wax based rustproofer.
thanks all i leave it as it is for the moment....
