Intermittent radio reception - almost none existent
Lewy
Post by Lewy » Sun 16 Oct, 2016 21:07
Hi fellow Zedders!
I'm hoping I have a common issue which is easy to fix.
I really struggle to get any reception for my radio and wondered if this is usually a problem in the boot area or if its behind the centre console.
I'll be stripping out the interior over the winter and could run a brand new cable but if there's an easy fix Id be really keen to learn.
Thanks in advance
Re: Intermittent radio reception - almost none existent
Post by mrscalex » Mon 17 Oct, 2016 00:43
What station do you listen to? I've had a lot of problems with Radio 2 (what else is a Z3 owner going to listen to really) this week and thought it might be their transmitters.
Just a long shot thought.
siwilson
Post by siwilson » Mon 17 Oct, 2016 08:18
Do you have a factory radio or has it been replaced with aftermarket? If aftermarket then its quite possible the antenna amplifier (in the boot) power feed is not connected to the back of the head unit. Aftermarket head units tend to have two wires that are not connected into the ISO connector. One for amplifier power and the other for antenna remote. Another option is the antenna amplifier at the base of the antenna. These do fail.
The first thing I would do is pull the head unit to see if everything is connected properly. Then check you are getting power to the antenna amplifier.
Post by colb » Mon 17 Oct, 2016 17:04
Take the whole unit out and unscrew the top underneath is a very small wire check to see if it is connected or got a bad joint. Its the feed to the mast. Mine had disintegrated and caused the fault you are having. I managed to solder a new wire in and that restored reception.
Lewy
Post by Lewy » Thu 20 Oct, 2016 12:19
Hi all, thanks for your input. Back of the h/u is definitely plugged in correctly.
Looks like colb has had the same issue. I'll give it a whirl at the weekend and post back results :)
Post by Brian H » Thu 20 Oct, 2016 12:55
Hi Lewy,
You posted about this a while back viewtopic.php?f=5&t=37886&hilit=radio#p351948 I assume the following link did not help?
viewtopic.php?p=211526#p211526
Lewy
Post by Lewy » Thu 20 Oct, 2016 19:42
Thanks Brian, given I've slept since then its well and truly left my memory. I'll take a look. Cheers.
Lewy
Post by Lewy » Thu 20 Oct, 2016 19:43
Users browsing this forum: No registered users and 9 guests
