Front Wheel Arch Liners
andy & fonz
Post by andy & fonz » Sat 26 Nov, 2016 17:12
Have removed my front wheel arch liners, got the offside sill off to knock out a dent and deal with the rust, the two fixed studs that help hold the liner in place sheared off, if I lift the carpets can I get too drill them out from inside or are they hidden in a box section? have drilled one from underneath but the one nearest the sill is a bit close me chuck on the drill is rubbing on the body so I can not get in square
thanks for your help
Re: Front Wheel Arch Liners
Post by mrscalex » Sat 26 Nov, 2016 19:12
They're the ones with the plastic nuts right? I have the same problem with the wheel sensor junction box.
Next time I'm nibbling the plastic nut with cutters.
andy & fonz
Post by andy & fonz » Sun 27 Nov, 2016 10:58
Hi yes that's them! think you are right I had soaked them in penertrating oil before I tried to remove them will try your method on the nearside
4wheels
Post by 4wheels » Mon 28 Nov, 2016 22:49
Post by mrscalex » Mon 28 Nov, 2016 23:16
4wheels wrote:dont buy off these lot... but
http://www.demon-tweeks.co.uk/Product.d ... oC48nw_wcB
I like that! That's a great solution - depending on what sits behind the stud. Ebay seller buycarspares2 has the identical tool for £19.
It's very similar to the principle of the spider leg plasterboard fixes that draw in behind. And they are very solid fixings - have put LCD TVs (okay 24") on the wall with those.
Post by mrscalex » Mon 28 Nov, 2016 23:23
Mind you the reviews are a bit hit and miss on Amazon.
https://www.amazon.co.uk/Sealey-AK393-T ... B00DSN2ITM
Post by mrscalex » Mon 28 Nov, 2016 23:40
This might be the better bet. Very good reviews and only a little more. Cheapest is £30 on Amazon.
https://www.amazon.co.uk/Sealey-AK3984- ... B00NVLM5CQ
Post by peter2b » Tue 29 Nov, 2016 19:07
I used one like the demon tweets when I built my kit car there are Ali nuts and stainless type
4wheels
Post by 4wheels » Tue 29 Nov, 2016 22:43
They are a common thing these days. Modern cars are put together with lots of them by robots of course.... And more Complicated methods like tox pressing.
Enables you to hang a huge force off a tiny m6 bolt
