Head gasket 3.0
alec.m
Head gasket 3.0
Post by alec.m » Sun 12 Mar, 2017 15:34
I appear to have a small coolant leak with some mayo showing on the oil filler cap which is making me think that I have a problem with the head gasket. I do a lot of short journeys, maybe the mayo is down to that but I`m concerned about the water loss.
Can anyone give me an idea what the cost of having a new head gasket fitted is likely to be? I`m past the age where I want to attempt this myself plus I`ve nowhere to do it.
Also I`ve used K seal in the past with excellent results but not too happy trying it on this engine. Any thoughts appreciated.
Re: Head gasket 3.0
Post by BladeRunner919 » Sun 12 Mar, 2017 16:47
Do you have any reson to think it's the HG? Is there anything on the dipstick to suggest there's water in the oil. As you say, the mayo in the coolant cap will probably be as a result of short journeys. Do you smell any coolant smells?
Howard Adams
Re: Head gasket 3.0
Post by Howard Adams » Sun 12 Mar, 2017 17:13
Hi, how much water are you loosing? 1st thing should be a coolant pressure check to eliminate any leak before automatically thinking it's the head gasket.
Is there water in the oil?, oil in the water?, is the coolest system over pressuring?, exsessive smoke/steam from the exhaust.
These engines have a reputation as being very reliable so hopefully it's something small like a water pump leak & all those short journeys.
H
alec.m
Re: Head gasket 3.0
Post by alec.m » Sun 12 Mar, 2017 17:32
Thanks guys, I`m only taking a guess at it being the head gasket. It needs topping up by about 250 ml a month. No external signs of a leak and no sign of anything on the dipstick. No steam or smoke from the exhaust. Performance is unaffected. I`ll also get the water system pressure tested this week.
Dino D
Re: Head gasket 3.0
Post by Dino D » Sun 12 Mar, 2017 22:38
Mayo is common on short journeys with these.
So is oil usage.
But HG issue not common at all I believe.
alec.m
Re: Head gasket 3.0
Post by alec.m » Sun 12 Mar, 2017 22:51
Unusually it doesn't use a drop of oil. It's coolant that it's losing. I hope I can find where it's going. Hate mysteries.
4wheels
Re: Head gasket 3.0
Post by 4wheels » Tue 14 Mar, 2017 21:03
You need to have a good look about. It's probably something plastic that's weeping. But might not do it hot. Only cool.. Or only hot. Or whilst cooling lol.
My audi only leaked when cooling.
alec.m
Re: Head gasket 3.0
Post by alec.m » Tue 14 Mar, 2017 21:57
Thanks 4wheels.
mwpe
Re: Head gasket 3.0
Post by mwpe » Tue 14 Mar, 2017 22:21
I was losing coolant slightly a few years ago and found a very fine crack in the header tank. easily fixed with a replacement from ECP.
alec.m
Re: Head gasket 3.0
Post by alec.m » Tue 14 Mar, 2017 22:25
Thanks mwpe. It's good to hear suggestions that don't mention CH. Some excellent thoughts to investigate.
NZ00Z3
Re: Head gasket 3.0
Post by NZ00Z3 » Wed 15 Mar, 2017 04:01
Also check out your crank case ventilation system. It can get blocked in the hose that goes to the dip stick tube from lots of short run in cold winter conditions.
Howard Adams
Re: Head gasket 3.0
Post by Howard Adams » Tue 21 Mar, 2017 07:26
Hi, what did you find reference the water loss, hopefully a coolant pressure check reveled any faults.
H
alec.m
Re: Head gasket 3.0
Post by alec.m » Tue 21 Mar, 2017 08:34
Hi Howard, Pressure of work has meant investigations are on hold. Mot is due in 6 weeks and I'm booked in at my local garage for some bits and bobs that need doing so it passes. He's going to do a pressure test while it's in. Hopefully some answers will be revealed. I'll update when I discover what's happening.
Users browsing this forum: Google [Bot] and 1 guest
