Minor Door shut adjustment?
Warrior
Post by Warrior » Wed 12 Apr, 2017 01:11
Passenger side door - clunnk.......closes perfectly every time.
On the drivers side I frequently find that I pull or push the door shut and have to do it a second time with a little more welly so some minor adjustment is needed but it's not obvious as to how this is achieved?
Re: Minor Door shut adjustment?
Post by BladeRunner919 » Wed 12 Apr, 2017 08:28
Are you sure you don't just need to grease the mechanism a little? When the door is shut properly, does it like up correctly with the rear panel? If so, that would suggest that there's not really an alignment issue and that it is just the mechanism binding a little.
Warrior
Post by Warrior » Wed 12 Apr, 2017 20:00
BladeRunner919 wrote:Are you sure you don't just need to grease the mechanism a little? When the door is shut properly, does it like up correctly with the rear panel? If so, that would suggest that there's not really an alignment issue and that it is just the mechanism binding a little.
I'll try a bit of WD40 and report back, thanks :P
Bonzo
Post by Bonzo » Thu 13 Apr, 2017 00:51
Or the top needs adjusting out a little?
Bonzo.
Post by BladeRunner919 » Thu 13 Apr, 2017 08:37
Use a bit of white grease rather than WD40 (which will actually remove any grease that's still there).
Warrior
Post by Warrior » Thu 13 Apr, 2017 16:14
Bonzo.
Yes, but how to adjust. Via the two Torx(?) bolts/screws on door?
Warrior
Good point.....i'll go on the scrounge this weekend :D
Bonzo
Post by Bonzo » Fri 14 Apr, 2017 23:53
You can adjust the door top lean, by loosening the two bolts on the bottom of the door and sliding them sideways a little.
:cheers
Bonzo.
