Screen Washers
andy & fonz
Screen Washers
Post by andy & fonz » Tue 16 May, 2017 17:50
Hi nearside screen washer packed up again today, Did the same last year then I removed the jet bodies and one way valve things, and cleaned them, great until today this time have taken the valves off and thrown them away, best the screen wash has ever been, got some real force behind it. If you are thinking off doing this you will need a small length of screen wash pipe has the one on the offside will not reach the jets when valve removed. ( right hand drive car )
Re: Screen Washers
Post by BladeRunner919 » Wed 17 May, 2017 08:06
Don't the valves stop the screenwash from draining back into the tank? I'd be interested to see whether after a few days you get a delay between pressing the button and any water coming out.
Tufarlian
Re: Screen Washers
Post by Tufarlian » Wed 17 May, 2017 08:39
The valves do stop the screenwash draining back.
If it clogs up regularly check the tank. You might find a surprising amount of gunk at the bottom.....
andy & fonz
Re: Screen Washers
Post by andy & fonz » Wed 17 May, 2017 09:29
Hi thanks for your input, Have removed and cleaned the tank (4 parts Milton steriliser 1 water, works a treat flush well afterwards). Can live with the delay, when I was a bit younger you had too pump the screen wash up by a manual pump on the dash.
Tufarlian
Re: Screen Washers
Post by Tufarlian » Wed 17 May, 2017 12:09
I remember manual screen washers :-)
The one way valves do eventually fail internally but they are really quite cheap to buy from your friendly neighbourhood dealer....
andy & fonz
Re: Screen Washers
Post by andy & fonz » Wed 17 May, 2017 16:36
must admit when these packed up it was a bit like the last straw, having just replaced the front ABS sensors ( by stripping and painting the front hubs) brake pad wear light wire and rear dampers, and come back from the M.O.T just for it to go on 5 cylinders and start running rich, no lights on the dash ? it was a bit of revenge. when I clam down may well buy some new valves
Re: Screen Washers
Post by mrscalex » Thu 18 May, 2017 07:29
Tufarlian wrote:I remember manual screen washers :-)
They are surprisingly cheap - £5 ish.
motco
Re: Screen Washers
Post by motco » Thu 18 May, 2017 07:40
andy & fonz wrote:Hi thanks for your input, Have removed and cleaned the tank (4 parts Milton steriliser 1 water, works a treat flush well afterwards). Can live with the delay, when I was a bit younger you had too pump the screen wash up by a manual pump on the dash.
When I was a LOT younger I didn't have any screenwashers at all!
The draining back might be an advantage in frosty weather as it is less likely to freeze in the reservoir than in the tubes.
Users browsing this forum: Bing [Bot] and 6 guests
