How do I remove a seized on starter motor?
DanHolman
Post by DanHolman » Thu 10 Aug, 2017 20:42
Hi all,
I'm trying to avoid removing the inlet manifold etc.... in order to remove the starter motor.
The bolts are out but the motor won't wiggle out. I've soaked the seam with WD over night. After two days, that has not worked. I think that the locator pin has corroded and seized it. There is a 0.6 mm gap to the casing above it. I might be able to cut through the pin. This gap looks intentional for this very reason...
Apart from soaking it a bit longer- what more can I do?
:shock:
Re: How do I remove a seized on starter motor?
Post by gookah » Thu 10 Aug, 2017 21:13
A bigger hammer, If its broken, then there is no harm in leathering it some more
John Wilson
Post by John Wilson » Thu 10 Aug, 2017 23:33
How about putting the car in gear and rocking it back and forward?
John Wilson
Post by John Wilson » Thu 10 Aug, 2017 23:38
Oh sorry, I was thinking the starter was engaged. If its not,that wont do any good.
Post by mrscalex » Fri 11 Aug, 2017 00:06
It will almost certainly be the locating pin seized. You can drift it out from the other side. I've had to do that twice but it was on engines out of the car. So I can't think if there is room to do it in situ.
You can use all the releasing fluid you want but it won't really help. It gets very stuck.
When you put it back together you need to clean the hole and pin out so it's a looser fit.
DanHolman
Post by DanHolman » Fri 11 Aug, 2017 08:08
Is it just a free floating pin?
I've seen a pic of someone punching it out from the front side after removing the manifold. Can it be punched out from either the front or rear side. And after you removed the pin did the motor assembly come away easily?
There's a gap (0.6mm) around housing where the pin is located. Could I get a hacksaw blade on it and cut through the pin?
DanHolman
Post by DanHolman » Fri 11 Aug, 2017 08:48
I'm Going to try freezing the pin with a compressed air dust off can. Hopefully this will shrink it enough to break the corrosion bond.
Post by mrscalex » Fri 11 Aug, 2017 08:51
This tells you what you need to know. I wouldn't try and cut through it.
http://www.pelicanparts.com/BMW/techart ... cement.htm
DanHolman
Post by DanHolman » Fri 11 Aug, 2017 11:24
Punching the pin requires taking out the manifold. I've tried freezing the pin. I can see it through the gap in the housing. So far no luck. I'm going to see if I can wind it out using a g clamp.
I can see the rusty pin through the gap and I can gat a hacksaw on the pin through the gap. What do you think of just cutting through the pin? This means that half will be stuck in the trans. housing but with the starter out I might be able to punch it out.
Is the pin essential when installing a new starter?
:shock:
Post by mrscalex » Fri 11 Aug, 2017 11:44
You'd only have 2 mounting points without the pin which may not be enough to stop the torque unseating it I guess. I wouldn't leave it out.
I'll have a look on my brother's 1.9 tomorrow (if i remember - busy day) and see if I can figure out something. I'm not sure cutting it is either wise or easy.
DanHolman
Post by DanHolman » Fri 11 Aug, 2017 12:53
Success!
I have successfully removed the starter motor from the BMW Z3 1.9L M44 4 cylinder engine without removing the manifold.
I will write up in detail about the procedure soon. I'm off to buy a cigar!
Thanks for all the input. Much appreciated. If anyone has any questions let me know.
Persistence.
As my first girlfriend used to say- Don't flake out half way through a job.
:P
Post by mrscalex » Fri 11 Aug, 2017 12:58
My other half usually says don't even bother starting the job these days.
Post by gookah » Fri 11 Aug, 2017 13:01
Success!
Persistence.
:P
you hit it harder then..... :D
Hendem03876
Post by Hendem03876 » Sat 12 Aug, 2017 22:26
mrscalex wrote:This tells you what you need to know. I wouldn't try and cut through it.
Cutting through it leaves two messes, you can also throw some heat on the surrounding area, I would also CAREFULLY drill out the keyway or line up hole and replace it with a slightly larger piece or rod stock.
Sent from my SM-G955U using Tapatalk
stevov
Post by stevov » Sun 13 Aug, 2017 12:50
Loosen the starter bolts 3or 4 turns then with socket on extension hit the bolt with a hammer one then the other. Once the starter has moved remove bolts fully
