MOT concern
HighSharpe
MOT concern
Post by HighSharpe » Sat 19 Aug, 2017 20:20
Hello all
just got the MOT done last week.
I have always had a clean MOT for the last 4 years. Got some advisories this time, from the same guy I've been going to all these years.
Are these a point of concern? Do these warrant immediate checking, or materially affect saleability?
Many thanks.
--HS
Advisory notice item(s)
Oil leak ()
Nearside Front Inner Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Inner Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Rear coil spring corroded (2.4.C.1b)
Offside Rear coil spring corroded (2.4.C.1b)
Propshaft universal joint worn ()
Re: MOT concern
Post by mrscalex » Sat 19 Aug, 2017 21:02
The oil leak and prop shaft joint wear are not frequently seen on advisories. The other items are and could go on fine for years if you do low mileage. It only needs a tiny bit of wear to get a tester excited.
The oil leak I would probably want to trace but might just be a cover gasket gone. And the prop joint could affect smoothness of drive.
Does it affect saleability? Perhaps. That's quite a long list however innocent.
Re: MOT concern
Post by colb » Sat 19 Aug, 2017 21:33
Testers seem to put down what were in the past quite acceptable items not even worthy of an advisory, it seems to be an arse covering method they have taken to using.
As to your advisories
Oil leak ()
Find the source and fix it, as said before probably just a gasket or o ring failed somewhere on the engine.
Rubbers probably looking a bit perished would be my guess.
Rusty springs, they are not that badly rusted that they are weakened and going to break, bet if you had painted them they wouldn't have been commented on.
Prop shaft universal joint worn ()
This is the one you want to do something about, if its got play in it then its going to get worse and cause you more problems, best get this one fixed.
stevov
Re: MOT concern
Post by stevov » Sat 19 Aug, 2017 21:38
Years of clean mot results always sets of alarm bells for me. Everything wears and nothing lasts forever. Would rather see advisories. Makes me think it was an honest mot and gives me things to check have been done. Clean sheets on 15-20 year old cars is not the norm.
Re: MOT concern
Post by mrscalex » Sat 19 Aug, 2017 21:55
Interesting view and I get the logic. But there are plenty of people both enthusiasts and non-enthusiasts who just take pride in keeping everything tidy.
Re: MOT concern
Post by Del » Sun 20 Aug, 2017 10:59
For me, the priorities would be the rusty coil springs and control arm bushes. With regard to oil leaks - many wouldn't even bother to mention that - although it's nice to cure it if poss. Advisories can be a bit subjective and silly at times - one MOT station near me insists on mentioning OE under-trays and engine covers obscuring items. Sometimes they also mention air fresheners hanging from rear view mirrors and remove them. :D
wonderloaf
Re: MOT concern
Post by wonderloaf » Sun 20 Aug, 2017 11:29
I had a similar set of advisories on last years MOT so have spent some time recently fixing them all, the only ones I couldn't fix were a perished propshaft rubber and corroded tank straps but put it in for this years MOT this anyway. So failed on front control arm bushes (which I fixed), but no mention of the propshaft rubber or corroded tank straps from previews MOT. On chatting to the MOT tech he said that the propshaft rubber was slightly perished around the outside but deffo didn't need replacing, and although the tank straps were corroded they were quite safe and it's a 16 year old car so what else do you expect?
Seems like the MOT testing can be quite subjective and the advisories can be a bit of a backside covering exercise!
2001 Titan Silver 2.2 Sport
Re: MOT concern
Post by peter2b » Sun 20 Aug, 2017 19:40
last year I had a winter check from my local bmw garage £25 they found worn from rubber bushes, rusty fuel tank straps, and a small spot of rust on a brake pipe , worn front brake discs, plus I got afree bmw umbrella, I think they hoped I would use them for the repairs but as I'm lucky to have a man shed, for £165 I got oem front supension arms + track arms +bushes and disc + pads 2.5 hrs later all done you can do it all on a jack +axel stands but 😊 I have a twin arm lift, (free use if local)
peterz3
therealdb1
Re: MOT concern
Post by therealdb1 » Sun 20 Aug, 2017 22:29
The most ridiculous advisory I have had is the "removal of an object from the windscreen obscuring the driver's view".
Any guesses what that object was???
The removal of the tax disc holder that was correctly positioned in the bottom left of the windscreen and until the previous month had been a legal requirement to be there on all cars!
I know the MOT testers have to cover their own backsides but tax disc holder... seriously. How did I manage to drive for almost 40 years before the tester removed it for me without it obscuring my view?
stevov
Re: MOT concern
Post by stevov » Mon 21 Aug, 2017 14:05
They cover their backsides because of this country's rapidly developing blame everyone but yourself mentality where the idea of personal responsibility and honor no longer exist. The socialist nanny state has a lot to answer for.
HighSharpe
Re: MOT concern
Post by HighSharpe » Fri 25 Aug, 2017 07:41
Thank you every one... I will go get these things checked and report back !
HighSharpe
Re: MOT concern
Post by HighSharpe » Fri 25 Aug, 2017 07:48
4wheels
Re: MOT concern
Post by 4wheels » Sat 26 Aug, 2017 23:27
Paint rusty things. A little bit of rust does not make things fail for a long time.
AdyDurn
Re: MOT concern
Post by AdyDurn » Tue 29 Aug, 2017 15:13
My Z has been advisory on the colour of the turn indicator bulbs for years. I've never changed them and they've never failed.
MOTs are a pain in the nose though, my Z originally had Irish plates, but one was cracked, enough to fail the MOT despite the point of the MOT being to get the car registered on a UK plate... Not only that but most people who print plates these days can only do a valid UK format plate. Ended up going to a trailer guy who knocked me up a pair of plates in the original Limerick format just for the MOT.
