Footwell Speakers Not Working
z3ddie
Post by z3ddie » Fri 15 Sep, 2017 13:25
I have already searched and not found anything to solve the problem of the footwell speakers not working.
I have a donor left hand speaker with the amp kindly supplied by a forum member and swapped it out but still nothing from the speakers.
The head unit is fine as I tried it in my friends car so any ideas or advice would be greatly appreciated.
The door tweeters and behind seats work fine so this has really got me scratching my head
z3ddie
Re: Footwell Speakers Not Working
Post by z3ddie » Fri 15 Sep, 2017 13:45
Forgot to add the radio is not working either
Post by colb » Fri 15 Sep, 2017 16:15
Need to check fuse that powers the radio if its not working, once satisfied you have power at the radio + connection check out the speaker connections at the rear of the radio head and at each of the speakers. You should find the fuse in the fuse box under the bonnet, also check for a fuse behind the radio. Also make sure the radio earth connection is ok.
z3ddie
Post by z3ddie » Fri 15 Sep, 2017 16:36
Thanks but checked all of that and they are all sound so still at a loss
Post by colb » Fri 15 Sep, 2017 20:14
If the radio works in another car then I would think you have no power on the loom in your car. Check with a meter or a test light with the ignition on at the accessory position and see if it has 12v on the radio feed. If there is no power and the fuse is ok then look for a break in the feed wire. If the fuse looks ok change it out for another one just in case it looks good but isn't.
Post by Robert T » Fri 15 Sep, 2017 23:09
Sounds like neither if the remote control wires are connected. There is one that operates the relay in the footwell amp, and another that supplies power to the aerial amplifier. I had the footwell speaker problem and just had to mate some additional bullets in my wiring loom - though this may have been aided by having a similar unit fitted previously.
Users browsing this forum: No registered users and 10 guests
