Poll for fun: Do you have a Strut Brace on your Zed
Let's see what people have got fitted (if indeed they do have them fitted) in the form of a strut brace to their Zed - to break it apart and make it a little more informative for those seeking brace information, in addition to voting in the poll, add as a message below this one, what Roadster or Coupe you have and what Strut Brace (or Braces Khush ) you have fitted - if you want to add a little more information about the brace then do so
E-tech Strut brace
Cheap and works well. pics on my web site.
Dinan strut brace and...
Strong Strut Butt Brace. Car is too low to fit body brace..
Cheers,
Lorraine
Z3 3.0
Lorraine
Z3 3.0
Just
Bolts on, Takes about 20 mins
Proven products or BMHeaven stock the E-Tech at £125 +P&P
- Runroadster
- Contact:
Strutts Fitted
Strong Strutts front, butt and body brace fitted . I wouldn't be without them each one makes a big difference. Tends to scrape on speed humps and uneven roads which is why I'll be fitting Bilstein shocks when I can.
The beautiful thing about learning, is no one can take it away from you. Tony & Reet.
e-tech strut brace
Re: Strutts Fitted
Just wondering, what shocks do you have now?Runroadster wrote:Tends to scrape on speed humps and uneven roads which is why I'll be fitting Bilstein shocks when I can.
I've the ACS sports pack and yes it is a little low but not enough of a problem to warrant changing. (there is scope for raising the butt strutt a little when I get around to it)
It is enough of a problem to prevent me going for a body brace as Lorraine mentioned above though.
Strong Strutt....
see pic 13 on their web site. Thinking about Butt strutt soon especially with £ / $ rate.
Strut Brace
Yes - Hamann strut brace - the rsukts are not as drmatic as some would have you believe, but it certainly does improve turn-in etc. Maybe front tyre wear will also be reduced on the inner shoulders. We wil see.
A Butt Strut will be fitted before the summer.
