Changing the MAF sensor on a S54
Hi all
Will be changing the MAF sensor this weekend on my S54. Can anyone give some advice on best way to go about it?
Many thanks
Simon
Many thanks
Simon
I've just bought some MAF cleaner for mine so will be removing/cleaning and replacing.
I believe you need security (hollow) torx drivers to remove the MAF torx screws, so I bought a set for £5 off eBay. I can't check my car as its stored 30 miles away so worth checking on yours
Otherwise I'm expecting it to be striaghtforward ie remove screws holding MAF sensor to airbox and pull it out /disconnect wiring ?
Out of interest why are your changing the MAF sensor ? (I believe they are pretty expensive) Have you tried cleaning it if your having problems ?
My cars running fine I'm just doing this as preventative maintenance as I have a K&N panel filter installed (by previous owner) and I'm curious how it removes as its a different setup (re how connected) than my previous S50.
Thanks. Just checked Torx screws are required so I will need to buy or borrow some before I start. Found this link from the M3 E46 list which describes the process and although its not exactly the same there is a strong similarity and does look straightforward.
[/http://forums.m3cutters.co.uk/showthread.php?t=11355url]
I have decided to replace as a precaution and prevention. I believe the heating and cooling cycle of the MAF can slowly deteriorate them over time so cleaning will help but it may still be underperforming. I appreciate that this a risk for me. £207 from main dealer is steep but should hopefully be worth it in the long run. I have been suffering from flatspots in the performance of the car and this now slowly getting worse so this is the next item on the list to do. Cheers Simon
Hi Simon
I replaced the MAF on my S50 a while ago as I too was getting flat spots. The difference was quite dramatic, once replaced the car pulled constantly right through the rev range. I read a recommendation to replace the MAF after approx 50-60K miles as it does deteriorate and the results totally outweigh the cost.
Gary had his S54 MAF replaced and saw huge improvement after suffering low power issues.
See Here
http://www.zroadster.net/forum/viewtopi ... hlight=maf
Ade
See Here
Ade
New MAF now installed and wow what a difference. Power up all through the rev range and throttle response very crisp. Easy install. Unplug the electrical connection, undo the screws (security torx), pull out the MAF unit, reverse procedure to fit new unit. Surprising to see the MAF so out considering mileage is only 44,000!
Simon
Simon
Surprising how much difference this makes, although I have another flat spot occuring at 3500rpm in 4th under load
I am running a standard air box and filter. The benefits are not just confimed to high load driving it also cruises more smoothly and is much easier to drive round town too. MAF problems seem to run through the M range cars M3 and M5, as far as I can see so I will be keeping an eye on this and hopefully it will not deteriote too quickly. Simon
- PERRIN Z3M
It's just like a single mis-fire
Steve
Flat Spot
I would describe it as; when you accelerate normally, foot down and the car is go go go right up the rev range in each gear, if you get a flat spot the car will go go go to a certain point up the revs (say 3500 rpm) then appear to ease off very slightly at the 'flat spot' (hesitate) then go go go again once it gets the other side of the flat spot.
Hope this makes sense
Ade
Flat Spot
Ade
- PERRIN Z3M
Thanks guys that makes sense and mine does not seem to do that, I actually took mine out last weekend and had a little blast with an RS4 and I was very pleased with the M///s performance. I kept up with him on a dual carriage way and we were very close he had more pull in 2nd due to more torque I guess but when in 3rd 4th and 5th it was very close.
steve
steve
