Free Fix for Constant Pressure Valve
HI All,
I am offering to post to the UK:
1. Viton Fluoroelastomer O-rings (23 high-temperature compound o-rings)
2. My custom-made 3mm x 4mm Kincrome impact drill bit
FREE OF CHARGE!!!
to anyone who wants to fix their constant pressure valve oil leak
All you have to do is do the same for a fellow forum member. Once you are finished with it, pass it on to the next bloke again and again until the 23-O-rings are used up.
I have been inspired by Pingu's excellent write up on how to fix the leaking constant pressure valve (thanks Pingu!!):
http://www.zroadster.net/forum/viewtopic.php?t=31401
In order to remedy this issue, Pingu gave instructions on how to machine grind an impact drill bit, the most time consuming part of this do-it-yourself job. In addition, replacing the OEM O-ring with another has proven to be only a short term solution as high oil temperatures adversely affect the rubber compound. Therefore, I have followed the recommendations from bimmerforum to use Viton Fluoroelastomer o-rings (1.5mm wide/14.5mmID):
http://www.mcmaster.com/#viton-fluoroel ... gs/=etco9u
I have 23 O-rings and my custom-made flat-head bit ready to go:
If you would like to do this job, I would be happy to send you the tool and o-rings as long as you pass it on the next forum member.
Just PM your address and I will post it straight away
cheers, SOMA:D
FREE OF CHARGE!!!
cheers, SOMA:D
1999 Cosmos Black MCoupe - 1 of only 27 original Australian imports
Very kind of you Do we know if this affects s54 engine as well?
Thanks again Pingu for a great write up.
After ordering the minimum number of o-rings, I still have heaps left over and the tool is 'job specific' so might as well pass it on.
I reckon if anyone is getting ready to do an oil change, might as well replace the constant pressure valve o-ring adding only an hour or so to the job.
I don't think M owners realize that the OEM O-ring becomes harden and brittle rendering it ineffective at maintaining oil pressure. I agree with Pingu this may constribute to vanos failure.
In that case I'm definately interested, my next service is probably a few months away though so someone may want to jump in before me? If not I'll happily go first
That's fine with me
Hi All,shantybeater wrote:In that case I'm definately interested, my next service is probably a few months away though so someone may want to jump in before me? If not I'll happily go first
just posted the 'Free Fix' kit to Shantybeater. If anyone wants to take this project on themselves, he will gladly pass it on to you.
cheers< Soma
Halo aus Australian,
Ich vermuete der Shantybeater koennen Ihnen eine von meinen Viton o-rings schicken. Er wird in dem kommenden Tagen die Pakete von mir bekommen.
Viel spass mit im schrauber Arbeit!....3mm dick und 4mm teif sollte hinhauen.
I'll be PM Shanty to use this after him or the next in line cheers Soma quite generous of you to offer this service.
No problem, i'll drop you a PM when I have themRST Driver wrote:Good to know.
Shantybeater, could you do me the favor?
Best regards,
Phil
Althulas is next so i'll get the remainder of rings & tool over to him next (minus RST Drivers and mine). I guess PM him if anyone else wants to get next in line?
Thanks again for this Soma, very generous of you..
RST Driver, PM sent
No Worries...glad to know 'M' owners are taking action on this!!sonic555 wrote:Althulas,Althulas wrote:I'll be PM Shanty to use this after him or the next in line cheers Soma quite generous of you to offer this service.
PM sent to you, hopefully I can use the kit from you when your done
- Badman gee
I did indeed, has it still not turned up? :s I can send another!RST Driver wrote:Shantybeater, did you send the O-ring to my address?
Best regards,
Phil
Mark, I can send one over to you as well but you really need the tool to make life easier, there is a bit of a queue now though ! I'd PM althulas and sonic (above)
Phil, PM me your address again for confirmation and if it still doesn't appear next week ill send anotherRST Driver wrote:Not yet. Maybe I have to wait another few days.
But thanks for shipping one o-ring to me. =)
Best regards,
Phil
^^ good question, my car will be going in on tuesday for its InspI+brake/coolant flush so i'll be getting my garage to fit the seal at the same time. When I get it back on wed/thurs I will send the rest onto Mark (althulas)
Thanks for the details, I got my specialist to fit the seal with its oil change.
Just a heads up, the seals & tool are on there way to 'althulas' so direct any requests onto him. Thanks again for this Soma, very kind of you to do this especially for free...
Hi guys just to update James has sent the seals and tool on but I'm away and unable to collect the parcel intill Friday and will contact people who want one of the seals to forward on or who next inline for the tool after I can get my car in for it's oils change and a few jobs including this one.
Mark
Mark
Re: Free Fix for Constant Pressure Valve
Got the items today James Cheers if I've followed the thread correctly Sonic is next in line for the tool and o ring kit. If anyone needs just the o ring can they pm me so I can post them on.
Just to say, what a brilliant thread this is. Z owners cooperating together to fix a common problem. Thanks to Soma for the inspiration and generosity for initiating this. This is what the site does best and is what will keep it thriving.
John
John
I got mine done today along side my inspection I and diff and gearbox oil change. There was a small leak from CPV and the o ring was solid like plastic. I believe Sonic is next in line PM sent.
Thanks again Soma my indie was impressed with your generosity and Pingu write up.
Update kit sent out to Sonic 28.03.12, I believe Swamper is next in line after Sonic
PM me if you still have constant pressure valve O rings kit
HI Sonic,
I hope everything is going well with the tool and rings. Have they been forwarded on to the next person in line? There is a gentleman over at Z3Mcoupe.com who lives in Ireland who would like to get a hold of a ring. I told him to have a look at this thread and make a request.
Keep those ring replacements going!!!
cheers< Soma
cheers< Soma
Info for when the free ones run out:
I have just got some o-rings for my Escort's FIP and they supplied next day for £1.50.
The o-ring for the constant pressure valve is 14.5mmID and 1.5mm cross-section
http://simplybearings.co.uk/shop/p51310 ... _info.html
There is a minimum order quantity of 2 and that will cost you £5.70, but 10 will only cost £6.95.
Viton is the real deal...that is a great price too
Whoever has the tool and rings presently, it would be good to get in touch with the next person in line. cheers< Soma
Hi Soma,soma wrote:HI Sonic,
cheers< Soma
Yes I have the kit and will forward to your Irish friend if he wants to give me his details.
I'm not sure who's next so if someone wants to get the kit I'll be happy to forward on.
Many thanks again Soma,
Regards,
Gary
Thanks Gary!
the request from the chap from Belfast over at Z3mcoupe was back in March so I assume he has it sorted.
send it along to whom ever is next in line
cheers, Soma
cheers, Soma
Picked up my roadster last week and would be keen to be added to the list please
Dave
Dave
Hi Gary,
do you still have the rings and tool...there is another request to fix a valve.
Please give us an update when you get a chance.
cheers< Soma
cheers< Soma
Does Anyone Know Where the rings and Tool have gone???
Hi All,
Anyone know where the tool and rings have gone? It has been a while so just wondering if those constant pressure values are being looked after.
all the best, Soma
all the best, Soma
i could do with ago myself...
Anyone have the tool and any rings??????? Pretty please
Looks as if the rings have disappeared along with the tool Gents! Too bad eh...I thought surely this would go around until either the rings ran out or the tool broke...
I have just given the tool I made to DaveP over on the coupe forum to use and said he could pass it on when he finished with it. No o'rings though as I bought a complete new valve when I did mine.
Aceman
Arctic Silver '98 Z3M
Previously;
Bright RED '99 Z3 2.8
Previously;
HI Aceman, thanks for passing on your tool....but this still does not explain where my tool and rings have gone.
