S50 Oil Service
5.5 litres x Oil (Mobil 1 SAE 0W-40 - £29.98 for 5 litres [Costco])
1 x Oil Filter Kit (11.42.7.833.769 - £13.96)
Total = £70 approx - with 4.5 litres of oil spare.
S50 Inspection 1
5.5 litres x Engine Oil (Mobil 1 SAE 0W-40 - £28.79 for 5 litres [Costco])
S50 Inspection 2
5.5 litres x Oil (Mobil 1 SAE 0W-40 - £28.79 for 5 litres [Costco])
6 x Spark Plugs (NGK PKR7A - <£50 for 6 on eBay)
1.7 litres x Rear Axle Oil (Castrol SAF-XJ SAE 75W-140 - £29.92 for 2 litres from www.nielsencdg.co.uk)
2 x Diff Plug Seal (07.11.9.963.355 - £0.35 ea)
Total = £150 approx - with 4.5 litres of Mobil 1 spare and 0.3 litres of diff oil spare.
S50 Inspection 2 (2nd Inspection)
1.7 litres x Rear Axle Oil (Castrol SAF-XJ SAE 75W-140 - £27.97 for 2 litres)
1 x Air Filter (13.72.1.730.946 - £27.62 [£15 from motor factor])
Total = £165 approx - with 4.5 litres of Mobil 1 spare and 0.3 litres of diff oil spare.
Items to be replaced periodically
1 x Sealant Cylinder for M-Mobility (every 3 years) (Mobility 1 - 71.10.2.229.882 - £33.80)
8.6 litres of Coolant mix (81.22.9.407.454 for 1.5 litres - £9.15). Mix should be 50/50 with de-ionised water. Total = £40 approx
1 litre of Brake Fliud (DOT 4 - available from a motor factor). Total = £12 approx (£15 for DOT 5.1)
Items to be checked that may need to be replaced during an Inspection 2
? x Valve Shims (11.34.1.401.416 to 11.34.1.401.424 (2.90mm to 2.55mm) - £7.01 ea)
Prices are from www.cooper-bmw-parts.co.uk unless otherwise stated (16/02/2012)
[edit] - Mobil One costs £29.98 for 5 litres (17/02/2012)
List of S50 servicing parts (incl prices)
- Z Register member
No, AFAIK it was recommended for the S54.aceman wrote:I thought the S50 required Castrol edge 10W-60 oil ?
Castrol website recommends EDGE 10W-40 for the S50, some folks say EDGE 5W-30, others say 0W-30 but the "right" oil for this engine has long been a topic for debate....
smartypants wrote:Conor?
With an M??
The World's gone mad
If someone PMs me a chassis number for an S54 I can do the same for that. Similarly, any other variants.
Specified oil for S54 is detailed in Enclosure 9
Specified oils for S50 are detailed in Enclosure 5, Enclosure 7, Enclosure 8 and Enclosure 11.
Enclosure 1 – General Information
Enclosure 2 – Testing Engine Oils
Enclosure 3 – Specified Oils
Enclosure 4 – Viscosity Grades
Enclosure 5 – Longlife 01
Enclosure 6 – Longlife 01 FE
Enclosure 7 – Longlife 98
Enclosure 8 – Special Oils
Enclosure 9 – SAE10W-60 for S54
Enclosure 10 – CNG Oils
Enclosure 11 – ACEA Specifications
Enclosure 12 – Measuring Oil Consumption
Enclosure 13 – Recording Oil Consumption
Enclosure 14 – Engine Oil Additives
Enclosure 15 – Oxygen Sensor Grease
