something for the S54 owners to try
offyourmarks
  M roadster S52
Post by offyourmarks »
Guys,
Have you tried to see if the throttle adaptation reset works on the MR with S54 engine?
For an E46 M3 and Z4 MC and MR the following procedure resets the ECU throttle response map. Over time the ECU learns your driving style and adapts accordingly. Over time the response can dulled
Sit in car and turn key to position II - wait for 10 secs
Turn key to position 0 and wait 10 secs
Turn key to position II and wait 10 secs then on to start up.
Go drive like an italian and the throttle response will be as sharp a butchers knife 8-)
Post by Badman gee »
is it april the 1st already?
:wink:
Post by Gazza »
It doesn't work, tried it years ago :wink:
Alfie
Post by Alfie »
Gazza wrote:It doesn't work, tried it years ago :wink:
Could that be coz your ///M was at the top of the 'Italian' scale already?
:D
A.
siwilson
Post by siwilson »
You could also disconnect the battery for a few hours. Same result.
Post by pingu »
I think it DOES work. It works on the 330 as well. I think it works on any fly-by-wire throttle.
It's supposed to reset the ECU to standard settings.
It may just be the placebo effect :D .
Post by Gazza »
:D
A.
I tried it before the remap :wink:
pingu wrote:I think it DOES work. It works on the 330 as well. I think it works on any fly-by-wire throttle.
It does work on the 330, not the S54 :wink:
offyourmarks
  M roadster S52
Ive done it on both mine and the wife's car and it has made a noticeable difference on both in terms of throttle response :)
macca
  Z4 sDrive20i M Sport
Post by macca »
Apparently this does work on Z4, so I've been told by Alan on the site!!
