alarm led?
alarm led?
Postby swamper » Sat 19 May, 2012 20:44
ok this is the one big bug bare with me at the mo.........
this led
has anyone moved it to a different place and what button have you replaced it with?.............as it looks rubbish
Re: alarm led?
Postby Badman gee » Sat 19 May, 2012 21:11
just push it out and replace with a blank.
Re: alarm led?
Postby swamper » Sat 19 May, 2012 21:19
na....it needs a button...i was thinking asc button but obviously it wont work
Re: alarm led?
Postby Dave L2 » Sun 20 May, 2012 08:21
swamper wrote:na....it needs a button...i was thinking asc button but obviously it wont work
HRS - for if and when you get a hard top?
Dave L2
Re: alarm led?
Postby Badman gee » Sun 20 May, 2012 09:30
here it is
and the rear screen switch and alarm led
Mark
Re: alarm led?
Postby swamper » Sun 20 May, 2012 12:49
:wink:
Re: alarm led?
Postby Robert T » Sun 20 May, 2012 21:57
Passenger eject button. :wink:
ZRoadster.net 2013 Calendar - ORDERS NOW BEING TAKEN
Re: alarm led?
Postby swamper » Sun 20 May, 2012 22:17
do they do a facelift version ... :D
sorry Dave...just seen this.....yep that looks like its going to solve the problem :wink:
Re: alarm led?
Postby Dave L2 » Mon 21 May, 2012 18:52
swamper wrote:do they do a facelift version ... :D
No problem, I won't take it personally. No, really, I won't... :bawl:
Dave L2
Re: alarm led?
Postby swamper » Tue 10 Jul, 2012 14:50
HRS button now in.. :D
Re: alarm led?
Postby g8jka » Wed 11 Jul, 2012 09:54
When I fitted my hardtop and new HRW switch at the rear of the console I removed the standard red LED as it was quite dull and not really noticeable.
This got me thinking of upgrading to a blue LED like the Clifford ones as they are much brighter, but I didn't know where to mount it. Anyway after seeing the newer BMW's I noticed that all the alarm LED's are situated in the rear view mirror so I decided to mount a nice new 10mm bright blue one there. Took the mirror apart and mounted the LED at the bottom and connected the wires back to the original LED wiring meaning it flashes exactly as the standard one.
It is much more visible outside when mounted in the rear view mirror and very bright at night time.
There's a couple of videos (not the best!) on youtube of it working here:
http://www.youtube.com/watch?v=SUlCKRsX-u4&feature=plcp
http://www.youtube.com/watch?v=hRDMPp-bzb8&feature=plcp
1999 BMW Z3 2.0 Titanium Silver with too many mods to list :-D :drive
Click For Progress Journal
Re: alarm led?
Postby swamper » Wed 11 Jul, 2012 10:03
nice one....but im not sure i fancy taking my mirror apart.....but a brighter bulb is the way to go :wink:
Re: alarm led?
Postby swamper » Mon 23 Jul, 2012 16:10
g8jka wrote:When I fitted my hardtop and new HRW switch at the rear of the console I removed the standard red LED as it was quite dull and not really noticeable.
ok iv change my mind....i reckon the way you have done it is the best way to go....can you point me in the right direction to buy the right LED :?:
i saw your car at siverstone and was going to ask you but you had wandered off ...... :D
Re: alarm led?
Postby g8jka » Wed 25 Jul, 2012 10:46
I can't remember which one it was, I brought a 10mm blue led and then an led bezel that will fit a 10mm led in it. I think something along the lines of this one should work. You can also get them in different colours.
If you could squeeze the led through into the mirror from the top where the wires enter to the bottom you may be able to do it without taking the mirror apart but you need to be extremely careful when drilling the hole not to hit anything inside the mirror. Other than this strip the mirror apart but be very careful. I don't know how much is inside the ///M mirror so you may need to open it anyway to see what's in there as this will also depend on where you can mount the LED.
* EDIT - You have a PM mate :D
Re: alarm led?
Postby swamper » Wed 25 Jul, 2012 12:38
PM back mate :wink:
Re: alarm led?
Postby swamper » Thu 26 Jul, 2012 14:42
well with some help from g8jka and a little pressy through the post we now have a full new up and running LED....cheers buddy ;)
when i sat in the car this morning i looked at the mirror...and started pondering how i was going to fit it..... luckily i took a drink out with me and low and behold there was a much easier solution....the LED is so bright you can even see it in the daytime 8-)
what do you think
Re: alarm led?
Postby g8jka » Thu 26 Jul, 2012 18:57
Looks good there mate! It's really bright especially at night the whole cabin will light up. Was it easy to fit?
Re: alarm led?
Postby swamper » Thu 26 Jul, 2012 19:30
yep...the coin slot was custom made for it....needs a bit of silicone underneath to fix the LED in place....5 mins once i got the wiring sorted :D
Return to M Roadster and M coupé
