Key fob problem...
S10OTY
Key fob problem...
Post by S10OTY » Tue 14 May, 2013 22:08
My key fob battery died so thought would just replace it, I have replaced it but now it doesn't work, when I click the button the led illuminates and stays constantly on... Any ideas?
stupot50
Re: Key fob problem...
Post by stupot50 » Tue 14 May, 2013 22:10
S10OTY wrote:My key fob battery died so thought would just replace it, I have replaced it but now it doesn't work, when I click the button the led illuminates and stays constantly on... Any ideas?
Needs pairing with the car I think, should be detailed in the hand book
1999 2.8 Arctic Silver Z3
2007 325d Msport - remapped
Post by Robert T » Tue 14 May, 2013 22:27
Pretty sure that the fob will be a transmit only device, so it won't be aware of whether the car is recognising it or not. I take it that you are talking about the separate key fob, as detailed here: http://www.zroadster.net/forum/viewtopi ... 686#p99686
S10OTY
Post by S10OTY » Tue 14 May, 2013 22:31
Hello,
Yes it's the 2 button house brick transponder, from this take it I need a trip to a garage to reprogram it with the car?
Post by Brian H » Tue 14 May, 2013 22:38
If you press the button and the light stays on, I would suggest that you have dirt trapped in the side of the buttons. The light should only be on when the button is pressed. The unit can be taken apart for cleaning.
Post by Robert T » Tue 14 May, 2013 22:41
Sorry, I was implying that I don't think the fob is working properly, not necessarily that it is no longer paired with the car.
Even if it does need re-pairing, then there should be no need to take it to a dealer. See: http://www.zroadster.net/forum/viewtopi ... =10&t=4959
S10OTY
Post by S10OTY » Thu 16 May, 2013 21:18
Hello,
Took the fob apart and cleaned it, it's working fine now.
Thanks both!
Post by Brian H » Thu 16 May, 2013 22:08
S10OTY wrote:Hello,
Thanks both!
Good news :thumb: thanks for letting us know.
