Brake Updgrade
Chazzy
Brake Updgrade
Post by Chazzy » Tue 08 Mar, 2016 14:22
Has anyone tried fitting 7/8 series E38 brakes with the E46 M3 disc as a front brake upgrade? If so how was it?
5harp3y
Re: Brake Updgrade
Post by 5harp3y » Tue 08 Mar, 2016 15:17
bolts straight on apparently but getting the calipers is a nightmare.
Easier options are larger e46 calipers and carriers. (£150 ish)
or for massive upgrade
porsche boxster brembos and custom adapters. (£400 is all in)
Chazzy
Re: Brake Updgrade
Post by Chazzy » Tue 08 Mar, 2016 17:40
Interesting - you can get the E38 calipers for about £120 on ebay.
Do you know anywhere in the UK where you can get the boxster adapter brackets? I've only seen them on American sites.
Re: Brake Updgrade
Post by bertiejaffa » Tue 08 Mar, 2016 19:34
from the darkest of dark sides....
https://zroadster.org/threads/upgraded- ... ain.11278/
I think BrianH has also done a brake upgrade so might be worth sending him a PM
EDIT - on ebay there are a few porsche breakers - I recently got some parts off one member called stevestrange007 and another called mister.porsche (porschepartsused.co.uk)
Chazzy
Re: Brake Updgrade
Post by Chazzy » Wed 09 Mar, 2016 11:18
5harp3y wrote:bolts straight on apparently but getting the calipers is a nightmare.
The boxster upgrade sounds pretty awesome - I'm guessing that's with E46 M3 discs as well. I quite like the sound of that, and won't break the bank!
Re: Brake Updgrade
Post by swamper » Sun 13 Mar, 2016 20:59
do they fit under the 17 inch OEM wheels?
Martini
Re: Brake Updgrade
Post by Martini » Thu 11 May, 2017 11:33
Have you looked at the PFC rotors and pads?
