Z3M Roadster issues s54
khanage1
Post by khanage1 » Mon 15 Aug, 2016 13:12
HI Guys - so my Z3M has intermittent EML light coming on and off - generally worse when cold starting once fully warmed up much better. Symptoms include limp mode, poor acceleration, juddering and and uneven accelerations very occasion poor idling and even cutting out after revving high. Only recent issues - before buying a MAF I disconnected the MAF and drove around a fair but made no difference with these issues so I assume MAF is ok. OBDII diagnostics done and showing pedal potentiometer sensor and temp sensor and air flow sensor (I assume the air flow sensor is the MAF) - local garage suggest changing the whole throttle bodies but having read here this seems unlikely as throttle bodies rarely get damaged as strong mechanical part. Forum suggests this is a very very common problem with these cars most likely either one or all the TSP and MAF sensors need changing/cleaning.
Is there a product code for all the sensors (TSP, temp sensor etc) on here I couldn't find any so I can slowly start buying all the sensors? Are the TSP sensors on the front of the engine and the one on the trotter actuator exactly the same part?
thanks guys - summer fast coming to an end and will be a shame to miss most of these days with a lumpy poor drive!!!
Re: Z3M Roadster issues s54
Post by Gazza » Mon 15 Aug, 2016 13:25
Mine used to go into limp if it revved over 7000rpm, switch of ignition and all was ok until the next time.
Changed all sorts of sensors and it was the O2 sensor on the exhaust, my Indy also suggested changing the Throttle Position Switch at the same time.
Don't forget to erase the codes.
khanage1
Post by khanage1 » Mon 15 Aug, 2016 14:26
Cheers Gazza - any idea of part numbers and if the TSP on the actuator is identical to the one on the front of the engine?
:-D :-D
Post by Gazza » Mon 15 Aug, 2016 20:59
He changed the TPS on the front of the engine.
Part No.s can be found on http://www.realoem.com/bmw/enUS/select enter the last seven digits of your VIN to browse parts for your car.
khanage1
Post by khanage1 » Tue 16 Aug, 2016 23:21
