M52 engine starter bolts
robert.rex
  M roadster S52
Post by robert.rex » Mon 17 Jul, 2017 12:58
I'm replacing the starter on my nephew's 1999 Z3M coupe and want to replace the two aluminum starter bolts, as recommended by BMW. Does anyone know which model engine uses the same bolts. I can'f find any source for bolts specific to its S52B32 engine. According to Wikipedia it is a E36 M3 platform. Does this mean it uses the same starter bolts as the E36 M3 engine?
Re: M52 engine starter botls
Post by Gazza » Mon 17 Jul, 2017 17:04
Use Realoem.com for part numbers
The part number you want is 07129904681
Click on the link below and then the part number, you will then see the other vehicles that use the same part.
http://www.realoem.com/bmw/enUS/showpar ... Id=12_2013
Any other part numbers can be found at http://www.realoem.com/bmw/enUS/select, just input the last five of your VIN
robert.rex
  M roadster S52
Re: M52 engine starter bolts
Post by robert.rex » Mon 17 Jul, 2017 17:51
Thank you, Gazza for the links.
