I set about the job of fitting my new Eibach Pro springs yesterday to sort out the larg wheel gap 30mm drop that should sort it out
the results, well juges for your self
I was expecting the ride to suffer with these springs but if anythink it has improved
Also fitted the ome wind defector today and removed make shift plastic slab the went across the back, what a diffrance that dose, i tryed to order the two sections that go in the hoops but my local dealer tell me one he can get no problem but the other is on back order and has been for some time
