which aux adapter and cigarette socket
jacob360
  Z4 roadster 2.0i
Post by jacob360 » Fri 12 Feb, 2016 17:33
sorry for another question, couldnt spot any similar below, just checking off a few minor faults with the car, the 12v cigarette socket doesnt seem to be working, check the fuse and its fine so looks like i need a new one, does anyone have the part number for this please (e85). also looking for an aux adapter, i bought one but it doesnt work, looks like it does not have the correct resistance from the positive to negative pins (from what ive read on google) any suggestions or recommendation for the correct one
thanks in advance
Re: which aux adapter and cigarette socket
Post by bertiejaffa » Fri 12 Feb, 2016 22:12
for all real part numbers check www.realoem.com - select classic and the Z3 is hidden in there - go through the options to get your exact model and then find the part diagram that will tell you the part number.
However for something like this I would be sending a PM to spursfaninacoupe
jacob360
  Z4 roadster 2.0i
Post by jacob360 » Sat 13 Feb, 2016 13:52
thanks, for others looking for this the aux adapter seems to be 65120153502
