SEATBELT GUIDE MOD FOR SALE...20 BUYERS NEEDED
Post by Southernboy » Fri 05 Jul, 2013 13:02
The consensus is that Black is the way to go...
Now I need at least 20 buyers to be able to supply them at £.17.50 per set (both seats). The price incudes postage. (£.7.50 to UK / EU.)
This will prevent the guides from breaking, is easy to fit and remove. Can be done with the seat and guide in place. Fitting time 10 minutes.
PM me with your order. Once I have sufficient orders, I will let everyone know where to make their payments and have them made and get them off to you within a couple of days. Postage delivery time is aprox 6 - 10 days. I will post registered mail with tracking number.
Re: SEATBELT GUIDE MOD FOR SALE...20 BUYERS NEEDED
Post by Southernboy » Fri 05 Jul, 2013 17:01
4 so far....c'mon guys... This will save you money and hassles at some point...you'll wish you had done the mod .... The cost of having a new guide fitted will be at least an hour in labour at an indie, plus the cost of the replacement part...:wink:
Post by Southernboy » Fri 05 Jul, 2013 17:21
4 confirmed and 4 probables....12 more needed please... :D
Post by Badman gee » Fri 05 Jul, 2013 17:39
It's a shame you can see the screws on the badge?
Post by Southernboy » Fri 05 Jul, 2013 18:16
I take your point, but it has to be removable... :wink:
Post by Badman gee » Fri 05 Jul, 2013 18:24
Southernboy wrote:I take your point, but it has to be removable... :wink:
I'm a fussy sod, a lot more than most.
Post by Southernboy » Fri 05 Jul, 2013 18:28
....a "bad fussy sod"... :twisted:
But one of the most likeable too. :wink:
Post by Badman gee » Fri 05 Jul, 2013 18:35
Put me down as probable at the moment sir.
Mark
walter05
Post by walter05 » Fri 05 Jul, 2013 19:17
Hi,put me down for a pair,atthe moment I dont need them but at that price they are worth saving for future problems.
wifevanda
Post by wifevanda » Fri 05 Jul, 2013 19:40
Put me. down for a set please
Fender2004
Post by Fender2004 » Fri 05 Jul, 2013 19:43
Would it be possible to have the silver ones if not I'll still have the black
Tufarlian
Post by Tufarlian » Fri 05 Jul, 2013 19:57
Put me down as a probable, but I think I'd prefer silver.....
wifevanda
Post by wifevanda » Fri 05 Jul, 2013 20:12
Black please
DC
Post by DC » Fri 05 Jul, 2013 21:18
Great solution, would an Allen or Hex screw look a bit better?
Dave.
Post by Badman gee » Fri 05 Jul, 2013 21:20
DC wrote:Great solution, would an Allen or Hex screw look a bit better?
Dave.
Yep I want allan or hex, your right
Post by Southernboy » Fri 05 Jul, 2013 21:52
It has to be a self tapping screw..I doubt you can get hex or allen head screws as small as is required here...The screw has to be no more than 6mm long, and no more than 2.9mm thread diameter. You can get machine screws that small with hex / allen heads, but not self tapping screws.
I don't have a problem if you want to go in search of your own screws though...maybe you can get a hex or allen head screw over there...if so, your choice... :wink:
Post by Robert T » Fri 05 Jul, 2013 22:48
Could you not use some of your (now infamous) sex bolts? You'd need to put a larger hole through the guide, but I think they would likely provide a stronger fixing than a small self-tapper. It would need a slim flange on the back piece, but I see they do come with both allen and slotted heads.
Post by Southernboy » Sat 06 Jul, 2013 06:31
Hi Rob.
The entire item is only 30mm x 30mm and each arm of the Z is only 7mm wide, and the space in the actual guide through which the seatbelt slides is aprox 2,5mm at it's narrowest in the center...See pic below.
The bulge in the base ostensibly keeps the seatbelt off the leather of the seat, but also makes it impossible to fit anything else in the aperture. The reason for self tapping screws is because they have such "coarse" threads and it's the threads cutting into the plastic which creates the locking strength vs a bolt with a nut at the other end which has more of a "clamping" system to hold parts together. If you guys can get "fancier" headed small self tappers in the UK, it's no big deal to fit your own screw. The critical issue is size and length...(who says size doesn't matter..) The thickness of the guide arms at the points where the screws moust be fitted is only 7mm. The overall width of the arm at that point is barely 32mm, and one needs to keep the size of the drilled holes as small as possible to avoid any weakening of the guide, hence the 1,6mm holes for a 2.5mm - 2.8 mm screw. Finally the screw can't be more than 6,5 mm long or it will penetrate into the area where the seatbelt will slide through, and if it does, it will rip the seatbelt fabric as it catches on the screw points protruding there. If you can find a "fancy" headed screw of max 3mm x 10mm you can use them, but remember to trim the screw down so as not to protrude through. The metal of the Z is 1,6mm plus 7mm of plastic = 8,6mm, minus ,5mm to be safely inside the plastic = max 8mm of thread on the screw. You will need to drill and insert the screws completely before trimming the screw to length so that you have already created a thread inside the plastic hole, once the screw is trimmed to length, you will lose it's sharp point making it more difficult to get it to cut into the plastic for the first time.
I would have also preferred to have had mini bolts, but there just isn't the space to work in the aperture, and anything protruding in there will catch on the seatbelt fabric.
If you look at the scale on the tool and the gap in the center of the guide..you will see 2,5mm is a generous estimate..it may be as little as 2mm... :wink:
Post by Southernboy » Sat 06 Jul, 2013 06:54
I'm off to a Specialist "screw" supplier this morning....if I find a fancier screw, I'll post a pic for comments.... (...no comments on a "specialist screw supplier"...especially after Rob's comments on sex bolts.. :roflmao:
Post by Southernboy » Sat 06 Jul, 2013 14:52
... :cry: Looked at two of the largest screw merchants...neither had anything other than the counter sunk head with a Phillips drive, and a domed head with Phillips drive....
It occured to me that the only places I had seen some really exotic self tapping screws was on appliances...stuff like microwave ovens have torx drive screws, unfortunately they're too big though...but no doubt, small exotic headed screws will be found in that industry...maybe someone on this forum manages or works in an appliance producing environment...they would have tons of exotica.
So, in short..the mod comes with countersunk or domed...my preference is countersunk for such a screw with Phillips drive....if I had a choice of exotics, I would like to see a very flat discus head of around 5mm dia with a torx 8 drive...black heads on a black Z, or brushe aluminium on a silver Z...I can dream I guess.
Just for your interest, here's a pic of the "Z" unmounted..you can see the curves required for it to seat snugly on the seatbelt guide...And those are the best screws available as self tappers go...
It is curved left to right and top to bottom, with a twist through the diagonal......sounds like time for a drink...with a twist of lemon.... :cheers :sunny
Post by Badman gee » Sat 06 Jul, 2013 14:59
I hope we can find some smaller screws, I don't like them. :( :( :(
Fender2004
Post by Fender2004 » Sat 06 Jul, 2013 18:22
[quote="Southernboy"]... :cry: Looked at two of the largest screw merchants...neither had anything other than the counter sunk head with a Phillips drive, and a domed head with Phillips drive....
Image[/quote
Looks good to me especially with all the curves :D
Three Syllables
Post by Three Syllables » Sat 06 Jul, 2013 18:36
Can you put me down for some, mines broken. This makes sense :)
Captain
Post by Captain » Sat 06 Jul, 2013 18:42
Just a thought, would a rivet not be a better option
Sent from my GT-I8190 using Tapatalk 2
hopalong64
  Z4 roadster 2.5i
Post by hopalong64 » Sat 06 Jul, 2013 20:06
Hi. I'll take a set in black with countersunk screws.
Post by Southernboy » Sun 07 Jul, 2013 10:30
Hi Cap'n...a rivet would need to extend into the aperture where the belt slide through, also, it would be a PITA if you wanted to remove the seatbelt and or seat...you'd need to drill out the rivets...but ultimately the intrusion into the seatbelt slide area isn't acceptable given the tight fit - 2mm.
Post by Southernboy » Sun 07 Jul, 2013 10:41
C'mon guys!! I have 10 confirmed...I need another 10 guys to order so that we can all save on replacing these guides in future...If your guide is broken at the moment, it will work as a fix to hold the broken arm in position, and if / when you replace the broken unit, you can transfer this mod to the new guide and prevent it from breaking - ever again!! :wink:
Here's a better pic for those who are wanting "silver" (polished aluminium)...
and one fitted on my car...
Tufarlian
Post by Tufarlian » Sun 07 Jul, 2013 13:38
I assume you need to drill 4 small pilot holes for the screws.
If you don't you would risk cracking the plastic, wouldn't you?
Post by Southernboy » Sun 07 Jul, 2013 13:46
Yep...The self tapper is 2.9mm thread diameter...a 2,5mm bit will be perfect...it allows the screw to cut a thread, whilst not being so small that it risks causing any cracks - hairline or worse....and can be tightened comfortably until the screw countersunk head beds into the reciprocal of the Z.
The holes in the Z are 3mmD. so the 2,9mm screw is a snug fit. The holes can be drilled right through the arm, just make sure you're carful not to hit the guide as it goes through...The plastic is soft enough not to require any serious pressure for a 2,5mm bit to pass through it... :wink:
Post by Badman gee » Sun 07 Jul, 2013 18:42
Don't like the screws, looks tacky.
snoops
Post by snoops » Sun 07 Jul, 2013 21:02
What about using tiny black screws ...the type used to mount computer circuit boards/components. They are very neat in appearance and should blend better ?
Image...........No Mods...... I like him just the way he is
Post by Southernboy » Sun 07 Jul, 2013 21:06
BMG...Snoops has the right idea...use your own initiative to source the screw you would prefer...The cost of the screws I have used were around 2p for four....I'm not familiar with the screws used in computer boards...but thanks for the heads-up...I'll pop into my IT support guy tomorrow and see what they have in their spares dept... :wink:
Post by Badman gee » Sun 07 Jul, 2013 21:09
I will source my own screws.
snoops
Post by snoops » Sun 07 Jul, 2013 21:23
Scroll down to the bottom of this page..... Any good ??
http://www.modelfixings.co.uk/self_tapping_screws.htm
Post by Southernboy » Sun 07 Jul, 2013 21:29
There you go !! those "button head panel screws look really neat with the allen key drive in the middle....yummy!!! I like the 2,2 mm thread x 9,6mm ones with the 4mm head !!! They would be perfect...you'd just need to shorten them to 8mm long so they wouldn't protrude into the seatbelt guide channel and snag on the belt itself!! Well done Snoops!
Those are the type of screws found on many appliances to fix their steel covers at the back.... :wink:
Post by Badman gee » Sun 07 Jul, 2013 21:32
Our Doris is top draw!
Post by Southernboy » Sun 07 Jul, 2013 21:33
Knows where to find a good screw!! :wink:
Post by Southernboy » Sun 07 Jul, 2013 21:40
Who would've thought that model aircraft people had such great stuff!! I'll need to find the local model shop here and check out their parts dept too...really great to learn about something new!! :wink:
snoops
Post by snoops » Sun 07 Jul, 2013 21:41
Oy.... I heard that
http://www.nutsboltsandthings.co.uk/soc ... k-109-scb3
Here you go... You can send me a free set for all this searching for you :wink:
Post by Southernboy » Sun 07 Jul, 2013 21:45
Hey Snoops...I'm in Johannesburg - South Africa...I can't get my hands on that stuff...you're there already and it's a phonecall for you...I have to scrounge about here or have stuff made from scratch!...and since I actually don't make anything from these little mods I come up with...I can't offer freebs...sorry. :cry:
Post by Badman gee » Sun 07 Jul, 2013 21:46
You can't beat a cracking screw!
Post by Southernboy » Sun 07 Jul, 2013 21:49
..BMG!!! I was wondering when you would "crack" yourself....up until now you've managed to resist the lewd comment....But I really think Snoops has found a cracking screw from the Model shop...nice neat head with a single eye in the middle for the allen drive!! :wink:
Post by Badman gee » Sun 07 Jul, 2013 21:55
Ha,
Fender2004
Post by Fender2004 » Sun 07 Jul, 2013 21:57
Looks like a great joint effort :)
Post by Southernboy » Sun 07 Jul, 2013 22:54
Thanks to Snoops....the name has implications... :wink:
John Wilson
Post by John Wilson » Sun 07 Jul, 2013 23:05
Are those allen head screws self tappers?
Post by Southernboy » Sun 07 Jul, 2013 23:13
Yep..the "button head panel" ones from the Model shop.....at the bottom of the page... and they give the sizes available...The 2.2mm x 9. ? long ones are perfect if they are trimmed shorter to 8mm. And I think they would look very smart.
John Wilson
Post by John Wilson » Sun 07 Jul, 2013 23:23
Ah, yes, they look good. I was looking at the other link from Snoops. The picture there doesnt look like self tappers.
Dave L2
Post by Dave L2 » Mon 08 Jul, 2013 09:04
How does the head diameter of the "Button Head Panel Screw" (4.0) compare with the head size of the screws shown in the example? If they are smaller would that allow for the bracket design to be altered to more accurately match the official zed "Z".
Post by Southernboy » Mon 08 Jul, 2013 09:06
Hi Dave, Personally I would prefer the button head screw..it's a 4mmD head vs a 5mmD countersunk screw head.
Users browsing this forum: Google [Bot] and 1 guest
