Makeshift shelter - condensation?
Warrior
Post by Warrior » Fri 18 Nov, 2016 01:53
I'm looking to build a temporary shelter to home Zeddie for the winter. She's been well looked after, washed, dried, cleaned polished & waxed on a regular basis but de-greening the roof has been difficult and as prices for 3.0i's seem to be firming up she probably deserves a little better.
The plan is to bolt together a wooden frame and cover it with correx board, the sort estate agents use for signage. I can source it cheaply, have plenty of bolts left over from building a pergola in the summer and reckon 100 quid will buy me enough timber.
Couple of questions. She'll be kept on a gravel drive atop a 6" base but should I put some correx or a plastic sheet down to prevent moisture rising underneath? Should I look for the best airseal or allow for some airflow into the chamber?
Re: Makeshift shelter - condensation?
Post by pingu » Fri 18 Nov, 2016 02:21
Airflow is good for airing the car, but bad when the wind gets up - as I found out a couple of winters ago :shock: .
Best might be to have air gaps, but to loop straps over the structure and bolt them to the floor.
Post by mrscalex » Fri 18 Nov, 2016 07:23
I've thought about doing similar although more so to work on the car in the dry.
I decided not to as the risk of it blowing away and causing damage is too great.
If you just want to protect the car why not look at a carcoon?
Warrior
Post by Warrior » Sun 20 Nov, 2016 21:25
the 500 quid price tag puts me of the carcoon :shock:
Post by mrscalex » Sun 20 Nov, 2016 23:05
Warrior wrote:the 500 quid price tag puts me of the carcoon :shock:
It's a lot of money to find but I don't think it's an insane amount to protect your pride and joy. Especially if a home-made assembly blows away and damages the car.
