Cruise control retrofit on a Z3 with M54
Has anyone retrofitted a cruise control on the M54(3,0L) engine? If I'm not mistaken, the M54 has an electronic throttle control and all the same actuators are used in the cruise control as well. So basically half of system is already in the car.
Whet else do I need to get?
- contol lever (obviously)
- control unit box (?)
- clutch sensor (or is the one already?)
- wiring harnesses?
Thanks in advance for the help!!
- wiring harnesses?
I did a cruise control on my S54 ///M (also fly by wire) quite easily using a kit form BMW that was actually meant for the 2.5i US version.
Take a look at my original thread and also follow the link to bimmerfest. I suspect your 3.0i would be the same.
http://www.zroadster.net/forum/viewtopi ... ntrol+done
Si.
Si.
My hunch is that yes it is.Z3C wrote:Nice, can it really be that easy?
I'll try to find out if the same parts would work with the M54
Thank for the hint!
If you take the minimum parts needed for the S54, and put the part numbers into RealOEM for Euro spec cars you get back that they are also specified for the Z3 M54 2.2i 3.0i models. Whether you need more than this is anyones guess but since the M54 is also fly by wire, my hunch is no. you may find though that coding would be required and that means a trip to a friendly local dealer or skilled indy.
Best of Luck!
Do you not also need the English cap - B61.31.1.390.968 Knob (English) others had to purchase this separatelyMr Silver wrote:Parts Required to retrofit cruise control on M44 3.0i:
1 off 65 71 8 380 054 interface
1 off 61 31 8 360 926 Switch assembly
Wiring is already in the M44 and probably others. Takes an hour (includes coffee break) and it works immediately.
Sure thing, I'll let you know how this will work out. It will be a while before I'll get to do any actual testint though. It's winter in here you see....Gio wrote:Can you let us know how you get on with this, as I would like to do the same for my 2.2i, which is also a M54 engine.Z3C wrote:Nice, can it really be that easy?
Thank for the hint!
My friend is also planning to hook up a cruise control on his M54 but we're both newbies and don't know how to start doing it. Lucky I was able to find a link in your post with a DIY on it. It would really come in handy for us. But I'm wondering what other parts beside these are needed to do the cruise control.siwilson wrote:I did a cruise control on my S54 ///M (also fly by wire) quite easily using a kit form BMW that was actually meant for the 2.5i US version.
Si.
- cruise control lever (obviously)
- wiring harnesses?
Any ideas or suggestions is appreciated.
I thought I'd give an update on my project:
I spend a good time in the web trying to find out if the cruise control retrofit kit “ 65 71 0 007 353 “ would work on my M54 3.0 or not --> with no result! I couldn't find anyone who could tell me if the kit will or will not work! (I guess I’ll be first to find out )
I also asked about this at my local dealer but of course they don't really know anything (big surprise!!). Actually they even said that it’s not possible to retrofit a cruise control on this particular model at all! But that of course just means that they don't have that option to sell.
Anyway, I decided to take the risk and order the kit. I figer that I have been spending so much money on my Z lately that a 100e frankly woun’t make any difference to my bankruptcy anyway !
Now waiting for the kit...
O_7777 :
I've added this to my 2.0 M52 TU which has a cable throttle but still has electronic throttle control for ASC. To check remove the underdash panel on the drivers side and have a look in the wiring loome that runs alongside the steering colume up to the steering wheel, you should find a small (I think it's a four pin) white plug, if it's there your good to go.
All thats needed is the cruise control switch from any E36, got mine second hand off E-bay for 20 quid, part number - 61318360926, remove the lower cowling from the steering colume, clip the switch in place under the wiper switch. The cutout for the cruise control switch is marked out inside the cowling, cut this out carefully then run the loome down the side of the steering colume. The other part required is the interface relay, part number - 65718380054, from BMW, this clips to a plastic bracket on the side of the steering colume under the dash. The loome from the colume switch plugs in one side of the interface the plug from the car wiring loome plugs in the other side, put the underdash panel back up and take it for a drive.
Sorry I've got no pictures
Thanks bowei and devon. I did find the thread started by estocks:
http://www.zroadster.net/forum/viewtopi ... l+retrofit
I actually did already read it ones but now as I read it the second time I got much more out of it.
There are excellent pictures of the interface, control lever and where it all goes to at the end of the thread. I don't expect to have to add any other components because all actuators swiches and brackest should already be in the car.
We'll see when I get my cruise kit which by the way has not been shipped yet!
I better call them about it!
O_7777 :
I thought it was standard on the 3.0i, obviously not, possibly only from 2002?
I have it on my 1.9, it must have been an option, and I never use it either.
HT
HT
HT
Titan's apprentice.
Titan's apprentice.
Official Devil's Advocate
Leg Puller
Micky Taker
I think I read somewhere that cruise control was standard in US market but not Europe. That should apply at least for 3,0 model.Hard Top wrote:I thought it was standard on the 3.0i, obviously not, possibly only from 2002?
HT
PS: still havent received the retrofit kit I ordered fron DDM tuning.
I hope to get it soon though. I'll let you know how it worked out then.
O_7777 :
Bad news!
I've been waiting for the CC-kit for a really long time and now I find out that BMW are not making them any more!!
So my CC retrofit project has just become a parts hunting project.
I think I only need the lever and the interface cable. Perhaps also the bracket but I figer that if I don't dond have one fitted, I'll just make one my self. How hard can it be, right?
I'm starding to look through the scrap yards now. The lever is probably easy to find because it' s the same one as on E36 3-series. The interface cable however was only fitted on Zs so thats a bit more tricky.
Of cource there is also the option that some reservesful zroadster member would have these parts for sale.... anyone?
O_7777 :
The kit may not be available but all you need are the lever and the interface box. The lever, as you say, is the same as the E36 3 series (part number 61318360926) and can usually be picked up at a breakers or on ebay . The interface is only fitted to the Z but is still available from Germany - I phoned my local dealer this morning to find out. The part number is 65718380054 and the cost is £53 including VAT. It is an special order only, non refundable item so check the part number I have given before ordering, it should read "interface, cruise control". Installation is easy and takes about an hour
Hello fellow z-owners.
I'm happy to inform you that I now have a conclusion regarding the cruise control retrofit on Z with a M54B30 engine.
I've been waiting for the retrofit kit for almost two month, only to find out that it's no longer available. Eventually I just ordered the parts separately. The parts that I ordered are the interface cable, the control switch and the button on the control switch with englinsh writing. The bracket for the interface cable is no longer available from the factory.
Today I finally received the parts. I installed them right away and... SUCCESS! it works! Just plug it in. I did have a bit of trouble finding the plug from underneath the dashboard. Actually I was already giving up and was about to ask for your help again when I finally found the plug just near the bracket for the interface cable underneath a bunch of cable ties. And yes, the interface bracket was fitted in the car already so I wouldn't have needed it anyway.
I love it how all the parts have their place under the dashboard and just snap in. Even the white connector that connects the interface cable with the control switch can be attached to it's own bracket right next to the interfase. All nice and clean!
So as a conclusion, if you're looking to fit the cruise control to your z with a 3,0 engine, all you need is the interface cable and the switch assembly. Actually mr silver sayed that right at the beginning of hte thread, even though he got the engine model wrong.
Budged --> 160 euros for the parts delivered to local dealer.
All in all, very satisfied with the mod.
O_7777 :
I've just received a package from Germany today with a kit that gives me the E39 Multi Function Buttons on the steering wheel (radio and cruise control) - can't wait to find the time to get it in the car!!!
Ferdinand
Volvo 144 1.8 B18 09/1967
http://www.zroadster.org
http://www.z3-forum.de
http://www.zroadster.com
Brilliant! I have a 2.2 M54 engine and have thought a lot about doing the mod myself. I still might but the traffic conditions here in south-east England are such that the opportunities to use cruise control are few and far between. What I would really like is a sport button similar to that fitted to my son's Z4M Coupé. He has the same dull throttle feel that we with fly-by-wire throttles have on our Z3s, but the sport setting almost totally eliminates the numbing effect. My Z is going in today for a service and brake fluid change, and I have asked the garage to remove/modify the clutch delay valve - a half way house to making the car more driveable, I hope.
There was a thread on here that detailed a mod to offer a sport button to the FBW models. I shall dig it out and see if it looks practical. The engine management is the same as the Z4 I believe...
It may be, but the programing will not be. All the sport mode does is to adjust the sensitivity of the throttle. Basically, you get more throttle for less push of the pedal. For this to work the DME needs to have both throttle maps in there and I suspect it will not.motco wrote:There was a thread on here that detailed a mod to offer a sport button to the FBW models. I shall dig it out and see if it looks practical. The engine management is the same as the Z4 I believe...
Hmm, sounds interesting. Which steering wheel are you going to use with this mod? Also how difficult is it to ged the radio controls in to the steering wheel? This was not available as a factory option on zedz at all, or was it?Ferdinand wrote:I've just received a package from Germany today with a kit that gives me the E39 Multi Function Buttons on the steering wheel (radio and cruise control) - can't wait to find the time to get it in the car!!!
Whats your budged?
O_7777 :
That's what concerned me when I first read it. It's all very well to assume that the loom is compatible with this mod, and the engine management is suitable for that one, but if the software is model specific it will not fly.siwilson wrote:It may be, but the programing will not be. All the sport mode does is to adjust the sensitivity of the throttle. Basically, you get more throttle for less push of the pedal. For this to work the DME needs to have both throttle maps in there and I suspect it will not.motco wrote:There was a thread on here that detailed a mod to offer a sport button to the FBW models. I shall dig it out and see if it looks practical. The engine management is the same as the Z4 I believe...
Anyway, this is the link:-
http://www.bmwmotorsports.org/mods/E3678/sportmode.htm
I'm using the M steeringwheel with E39 buttons - looking forward to getting it sorted and working... and it has never been offered from BMW price was 300 euro - all parts are new original BMW stuffZ3C wrote:Hmm, sounds interesting. Which steering wheel are you going to use with this mod? Also how difficult is it to ged the radio controls in to the steering wheel? This was not available as a factory option on zedz at all, or was it?Ferdinand wrote:I've just received a package from Germany today with a kit that gives me the E39 Multi Function Buttons on the steering wheel (radio and cruise control) - can't wait to find the time to get it in the car!!!
Whats your budged?
Ferdinand
Good luck with that. I never heard aboud a mod like this so it's going to be quite unicFerdinand wrote: I'm using the M steeringwheel with E39 buttons - looking forward to getting it sorted and working... and it has never been offered from BMW price was 300 euro - all parts are new original BMW stuff
I hope you're plannig to take lots of pictures and write a thead about your experience. It would be some interesting reading.
O_7777 :
Cruise control retro fit
Hi all
Just a quick note to thank everyone who contributed to this thread. I saw the postings and was tempted. I too couldn't source the complete kit so obtained the components individually. Just plug and play! Great for use as a speed limiter
Thank you all again
Thank you all again
For those interested there's a stalk on Ebay: Item No. 230570617341 at $19.00 plus $15.00 postage to UK. Also, the current price from a main dealer for the interface is £53.00 inc VAT.
Personally I don't think I'll bother because, as I said before, the south of England traffic precludes the use of cruise most of the time and roughly £75-£80 could be better spent elsewhere.
Re: Cruise control retrofit on a Z3 with M54
I am currently trying to fit the kit to my M54 2.2 but cannot locate the white three pin plug that connects to the interface module. Can anyone help please?
It should be the. Probably folded and fastened somewhere behind the column. It took me really long time to find it too when I was doing mine. In fact I was just about to give up when I finally found itmotco wrote:I am currently trying to fit the kit to my M54 2.2 but cannot locate the white three pin plug that connects to the interface module. Can anyone help please?
O_7777 :
Z3C Thanks, I actually read your post on the problem and went back to my car renewed with hope. Alas, no luck. I shall try again when I can.Z3C wrote:It should be the. Probably folded and fastened somewhere behind the column. It took me really long time to find it too when I was doing mine. In fact I was just about to give up when I finally found itmotco wrote:I am currently trying to fit the kit to my M54 2.2 but cannot locate the white three pin plug that connects to the interface module. Can anyone help please?
I was told by an enthusiast recently that it is possible to do this very upgrade to my 1999 facelift 2.8 and all I needed was the switch and the interface whichb can both be purchased for around £90. But I have seen mention in this thread of a 'clutch switch' and my car is auto - so will this be an issue? Cruise control is very tempting with all these average speed cameras around the M25 and in roadworks elsewhere, saves keep having to check the speedo!
I don't think that's correct. Your car has a throttle cable, whereas the M54 engine has a fly-by-wire throttle. For your car you need an actuator that physically opens the throttle.Alan W wrote:I was told by an enthusiast recently that it is possible to do this very upgrade to my 1999 facelift 2.8 and all I needed was the switch and the interface whichb can both be purchased for around £90. But I have seen mention in this thread of a 'clutch switch' and my car is auto - so will this be an issue? Cruise control is very tempting with all these average speed cameras around the M25 and in roadworks elsewhere, saves keep having to check the speedo!
Sorry still trying to get my head around all this body shape numbers and engine mumbers?I don't think that's correct. Your car has a throttle cable, whereas the M54 engine has a fly-by-wire throttle. For your car you need an actuator that physically opens the throttle
Mine is a M52TU 2.8 twin vanos unit which I understood to have a fly by wire throttle whereas the M52 2.8 does not?
The auto definitely does not require the clutch switch plug. I believe that the fly by wire will require only the switch and the switch interface (still available from BMW) and it's plug and play.
Hope this helps
Regards.
Hope this helps
Regards.
There is a clutch switch bridging cable for vehicles with automatic transmission. Part #11 below:
Cruise control - BMW parts catalog
andThe auto definitely does not require the clutch switch
Can someone confirm whether I would require a clutch switch bridging cable for my M52TU 2.8 auto and if so explain in laymans terms what it does?There is a clutch switch bridging cable for vehicles with automatic transmission. Part #11 below:
I've not done it, and I don't have an auto either, but from reading the descriptions above (click the pic to see) it is an either or. You fit the switch to a manual car or you fit the bridging cable to an automatic. I assume it fools the control unit into thinking that a switch is present. The picture implies a single connector with a bunch of wires coming back to itself, so it looks like it just shorts certain pins together. This should be described in the BMW retrofit instructions if someone has them.Alan W wrote:Can someone confirm whether I would require a clutch switch bridging cable for my M52TU 2.8 auto and if so explain in laymans terms what it does?
EDIT: A PDF of the installation instructions for the kit can be downloaded from here: http://www.gavandkel.co.uk/Z3.html
The instructions are not very clear, but it is as I supposed above - you fit one or the other depending upon whether you have manual or automatic transmission.
..er, the clutch switch is operated by the clutch pedal! Guess how many clutch pedals there are fitted to a vehicle with automatic transmission?
Regards.
Regards.
