I change my own oil and need to reset the service meter. I also triggered the airbag light and another one when I did not disconnect the battery while working on the car. A regular OBD code reader wil not zero out the trouble lights on my dash.
There are several BMW reset tools available, but I am not sure if they will fix the airbag and other light on the dash.
What reset tools do you use and recomend for my use?
Thanks!
BMW reset tool
BMW reset tool
"Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats." Rat from The Wind in the Willows, Kenneth Grahame author
I use a Peake SRS tool to reset my airbag light however there's some recent +ve feedback on the Bavarian Dominator range. These look a cheaper alternative (even with International shipping) so probably worth a punt.
Current...1998 ///M Coupe
Previously...1997 Z3 2.8
+1 for the Bavarian Dominator airbag reset tool.
Found 2 faults in my system and then reset the airbag once they were resolved!
£39.50 well spent...
BMW Z3 2.0 Titan Silver - Progress Thread
(Pictures - http://s852.photobucket.com/home/gazhyde/allalbums)
Was there a fault, or did it just need resetting? When I changed my seats over I ended up with 2 fault codes, both of which reset ok.theduck wrote:Afraid its negative feedback from me on the bavarian dominator airbag tool as it couldnt read my fault codes. Took it to a specialist in the end and £10 later all sorted.
Dominator
Interesting. I had the seats out in my driveway and turned the key on to be able to unlock the steering wheel so I could push it back into my garage when it started raining. I will look for a source in the States.
If it helps Grandpa, this is the model I have. Seems readily available in the US.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0554032888
Gary
Gary
