Vanos rattle solved
Vanos rattle solved
Postby boanke » Sun 24 Jul, 2011 12:44
Hi, I am a mem,ber from sweden and I read on a swedish forum as well. I just read a post that has solved our vanos rattle, I have done it and it worked wonderfull. from my vanos there is just silence. How to do it?
http://www.realoem.com/bmw/diagrams/i/o/42.png On part 2 on the top there is a hex 6mm (I think) loosen the locknut turn hex out for 1/2 counter slowly then you can hear the rattle disappear. tighten the locknut and you are done. You must take the engine to normal drive temp and have it idle turn slowly and listen. I turned my hex nearly 3/4 counter. :drive
Kennet
boanke
Postby boanke » Mon 25 Jul, 2011 08:21
Maybe this is old news, that a fast fix is out.
kennet
boanke
Postby Deano1712 » Mon 25 Jul, 2011 10:03
mmm so you adjust the main PRV setting to solve the rattle? Increase the pressure and you risk blowing the covers off the solenoids (with complete engine oil loss), or reduce the pressure and the Vanos no longer functions. Maybe I'm missing something...
Postby boanke » Mon 25 Jul, 2011 12:35
The rattle is coming from gears behind vanos and depends on a spring that have lost elasticity over time. Spring decide how much oilpressure. Softer spring = low pressure and to much clearance between gears = rattle. to compensate for soft spring one can adjust oilpressure upp to normal level. Or one can buy a new vanos, I dont think one can buy just oiloressure regulator. This is not my idea I just fel that everyone that have a s50 can enjoy a silent vanos,according to swedish Autopower the tip come from Germany to Autopower. http://www.autopower.se/forum/topic.asp?id=241942 Here is a translation of one reply.
Believe it is because there currently is vacation time. It had certainly been more pull in this thread otherwise.
The solution to the vanos rattle has been with the mechanics of the BMW workshops in Germany for at least 15 years (according to member of German forum) but has apparently had a duty of confidentiality or the like thereof. And here in Sweden "has no idea" about this when I asked.
I got a tip via pm to try this by starting a thread in a German forum about my problem. Where it was apparently quite well known method among member why.
One can in retrospect to wonder how many vanosenheter who replaced unnecessarily. The fact that many engines have been replaced due vanosras, well. Read the bottom bracket race instead. Vanosras is a concept that apparently only exists here in Sweden, unfortunately.
To send the device to Dr. Vano is reportedly 200-300 mil then rattle back (pressure). Changing the oil viscosity / oil the 100th mil then will rattle (print again).
Rattle is well known that the pressure in the unit has become too low over time and mekaninken loose in it, hence the rattle.
What I am looking for full right now is what the pressure will be on the vanosenheten so it is possible to measure and obtain a more precise adjustment of pressure.
And for those of you who have not tried, like bums with a 19mm wrench and 6mm Allen key and adjust the engine is warm. It works! We S50 owners should not have to be ashamed of rattling vanos!
boanke
Mr vanos
Postby alanandjudi » Wed 27 Jul, 2011 20:09
Very interesting. Just got my car back from (Mr Vanos) Darlington after full vanos overhaul, replacement seals etc. Its quiet as a mouse now, smoother and seems more responsive. First class job would recommend Steve to anyone that has vanos problems. What he doesnt know about the vanos isnt worth knowing. Now I just need to find time to drive it and enjoy it. :D [/list]
alanandjudi
Postby boanke » Fri 29 Jul, 2011 17:23
After some test and investigation it seems like it is to by a new regulator, or just do the adjustment.Some guys here in sweden has done it and we think it is the ultimate solution for our problem. why have it not come up before? It is a very simple thing to do.
It is just thing that I have in my mind, why is there not a bigger interest for this then 2 different post in this tread? Do you think the swede are trick you?
kennet
boanke
m
Postby hornel Z3M » Fri 29 Jul, 2011 19:27
Hi boanke. We are all very interested in the vanos issue. I had my vanos serviced a couple of months ago and i feel it is not a problem as i dont notice any noises or rattles, i also think all M owners do there own thing with their vanos issues. :wink:
hornel Z3M
Postby Althulas » Sat 30 Jul, 2011 09:09
boanke wrote:After some test and investigation it seems like it is to by a new regulator, or just do the adjustment.Some guys here in sweden has done it and we think it is the ultimate solution for our problem. why have it not come up before? It is a very simple thing to do.
kennet
To be honest my knowledge about the vanos is very limited. Mine has a small but annoying growl approximately 1200 -2000 rpm. I am waiting to have the pennies for mr vanos to repair mine.
Interesting post made here about a simple cure for the growl but not possessing enough knowledge on how the internal workings of how the vanos works does make one think twice about doing this mod as I would be concerned about blowing my solenoid seals and I'm sure other members have doubts too due to lack of knowledge and a s50 is expensive to replace if it goes wrong. What is needed is a better explanation on how this mods works.
Althulas
Postby Gazza » Mon 01 Aug, 2011 15:39
boanke wrote: why is there not a bigger interest for this then 2 different post in this tread? Do you think the swede are trick you?
kennet
Not at all :wink:
Gazza.
2001 M roadster S54 Image 1965 Mustang 289 Fastback, 1968 Mustang Coupe 331 Stroker, 1967 Mustang 289 Fastback
Postby Bill- » Mon 01 Aug, 2011 17:45
whats a Vanos rattle like I have a small one at about 1500 revs when pulling away..
Bill-
Oops, sorry. I dont have an M, is it only M related?
Bill-
Postby dave635 » Fri 26 Aug, 2011 11:51
As my S50 vanos is rattling a bit i'm interested in this possible fix, has anyone tried this or have any more info supporting or otherwise ?
Cheers,
Dave.
dave635
Postby boanke » Wed 31 Aug, 2011 08:07
Here is the latest from sweden. the discussion i now about that if one do this mod the rattle is gone but the pressure is not rised but lowered. That is not the ultimate solution. quite many has done it my self included. The silence from engine is a blessing and I havent noticed any loss of power.
boanke
boanke
Postby Gazza » Wed 31 Aug, 2011 09:29
Thanks for the info Kennet
Gazza.
Postby dave635 » Wed 31 Aug, 2011 13:04
thanks for info,
cheers
dave635
Re: Vanos rattle solved
Postby boanke » Sat 05 May, 2012 05:53
Update about pressureregulator. I have now bought a new pressureregulator for vanos and mounted it yesterday. I noticed that idle became a bit lower and vanos rattle little quieter. But now I really know vanos oilpresssure is right.
"Time is on my side" - Edgar reese
http://www.zroadster.net/forum/viewtopic.php?t=33754
boanke
Return to M Roadster and M coupé
