New Z3 Owner. Couple of issues
uggers2k
Post by uggers2k » Sun 25 Sep, 2011 22:12
Hi all,
Have joined the BMW Z3 club after purchasing a 1.9 2000 Z3 in Topaz blue with 49K.
I have owned the car for 6 weeks now and just took it on a 300 mile ride.
Am loving the car except having a few issues:
The gear change is not as smooth as it should be. It feels kind of stiff and notchy. Is this common on a Z3? Any possible improvements?
Also, the revs seem to be a little low on initial startup. Once the car is warm, and at traffic lights, it sometimes seems to be idling too high (Around 15K RPM). Again is this a common problem. Have read that the cam sensor could be faulty.
Any information required to sort the 2 above issues out would be grateful.
Cheers all
aceman
Post by aceman » Sun 25 Sep, 2011 23:04
Hi and welcome, :D
The gearbox on most Z3's is what can only be described as notchy what I call a "mans gearbox" so I doubt there is any problem with yours.
With regard to your idling problem if it doesn't cut out when started or has a sudden misfire/hesitation when accelerating then I doubt it is yous cam sensors. What I suspect is you have a split air intake hose where it locates onto the throttle body usually the little pipe that branches off to the idle control valve. This allows the engine to suck in unmetered air making the engine run lean at idle and upping the revs a bit. A new one from BMW is around a tenner so not too expensive.
Aceman
Arctic Silver '98 Z3M
Previously;
Bright RED '99 Z3 2.8
uggers2k
Post by uggers2k » Mon 26 Sep, 2011 06:23
Cheers Aceman,
Will check the air intake hose later on. Hopefully a cheap fix.
DC
Post by DC » Mon 26 Sep, 2011 09:52
Also check that your dipstick is pressed firmly down to seal the hole it goes into, mine runs a bit lumpy on tickover if I leave the dipstick up a fraction.
Dave.
uggers2k
Post by uggers2k » Mon 26 Sep, 2011 20:16
I have checked all pipes and they seem Ok except the one highlighted in the picture. It is split. Anyone know what this pipe is called, so I can get a replacement?
<a href="http://s1231.photobucket.com/albums/ee5 ... =file1.jpg" target="_blank"><img src="http://i1231.photobucket.com/albums/ee5 ... /file1.jpg" border="0" alt="Photobucket"></a>
Post by Brian H » Tue 27 Sep, 2011 09:59
uggers2k wrote:I have checked all pipes and they seem Ok except the one highlighted in the picture. It is split. Anyone know what this pipe is called, so I can get a replacement?
Hi uggers2k
At first I thought this was some form of conduit covering electrical cables but then spotted this pic on my search.
From the pic above I believe that the part you are looking for is part 9, see below. If you click on item 9 it will take you to the part number.
Emission control-air pump - BMW parts catalog
I am not that familiar with the M43 engine, can someone else can confirm this?
uggers2k
Post by uggers2k » Tue 27 Sep, 2011 13:33
Superb, thats the one, thanks
Bill-
Post by Bill- » Fri 07 Oct, 2011 19:34
Ardchyle, What a top man you are :)
Users browsing this forum: Google [Bot] and 11 guests
