Free Fix for Constant Pressure Valve
Postby soma » Sun 06 Nov, 2011 12:39
HI All,
I am offering to post to the UK:
1. Viton Fluoroelastomer O-rings (23 high-temperature compound o-rings)
2. My custom-made 3mm x 4mm Kincrome impact drill bit
FREE OF CHARGE!!!
to anyone who wants to fix their constant pressure valve oil leak
All you have to do is do the same for a fellow forum member. Once you are finished with it, pass it on to the next bloke again and again until the 23-O-rings are used up.
I have been inspired by Pingu's excellent write up on how to fix the leaking constant pressure valve (thanks Pingu!!):
http://www.zroadster.net/forum/viewtopic.php?t=31401
In order to remedy this issue, Pingu gave instructions on how to machine grind an impact drill bit, the most time consuming part of this do-it-yourself job. In addition, replacing the OEM O-ring with another has proven to be only a short term solution as high oil temperatures adversely affect the rubber compound. Therefore, I have followed the recommendations from bimmerforum to use Viton Fluoroelastomer o-rings (1.5mm wide/14.5mmID):
http://www.mcmaster.com/#viton-fluoroel ... gs/=etco9u
I have 23 O-rings and my custom-made flat-head bit ready to go:
If you would like to do this job, I would be happy to send you the tool and o-rings as long as you pass it on the next forum member.
Just PM your address and I will post it straight away
cheers, SOMA:D
1999 Cosmos Black MCoupe - 1 of only 27 original Australian imports
soma
Postby Gazza » Sun 06 Nov, 2011 17:13
What a gracious offer :bow
Gazza.
2001 M roadster S54 Image 1965 Mustang 289 Fastback, 1968 Mustang Coupe 331 Stroker, 1967 Mustang 289 Fastback
Postby shantybeater » Sun 06 Nov, 2011 18:09
Very kind of you :) Do we know if this affects s54 engine as well?
Progress Thread:http://www.zroadster.net/forum/viewtopic.php?f=32&t=36117
Postby Brian H » Sun 06 Nov, 2011 19:06
shantybeater wrote:Very kind of you :) Do we know if this affects s54 engine as well?
Shanty, below is a quote from Pingu's original post.
pingu wrote:The constant pressure valve (11 11 1 318 185) is fitted to the S50B32 and the S54 engines.
HTH
Postby pingu » Sun 06 Nov, 2011 20:09
soma. well done fella.
Postby soma » Sun 06 Nov, 2011 23:04
Thanks again Pingu for a great write up.
After ordering the minimum number of o-rings, I still have heaps left over and the tool is 'job specific' so might as well pass it on. :)
I reckon if anyone is getting ready to do an oil change, might as well replace the constant pressure valve o-ring adding only an hour or so to the job.
I don't think M owners realize that the OEM O-ring becomes harden and brittle rendering it ineffective at maintaining oil pressure. I agree with Pingu this may constribute to vanos failure.
soma
Postby shantybeater » Sun 06 Nov, 2011 23:15
In that case I'm definately interested, my next service is probably a few months away though so someone may want to jump in before me? If not I'll happily go first
Postby soma » Mon 07 Nov, 2011 12:29
Great Shanty....lets see if others are planning to do this fix sooner. If not, I will send it along to you ok?
soma
Postby shantybeater » Mon 07 Nov, 2011 13:39
That's fine with me :)
Postby pingu » Mon 07 Nov, 2011 13:47
soma wrote:...adding only an hour or so to the job.
It's a 15 minute job when the car is already on the ramp and you have the tool.
I'd get it negotiated in with the price of the service. :D .
Postby soma » Tue 08 Nov, 2011 06:35
Only 15 minutes....all the more the reason to get this sorted if you have a leak...surprised I've only had one offer so far.
I suppose the Northern Hemisphere is getting a tad chilly this time of year for working under cars eh? :lol:
soma
Postby soma » Fri 11 Nov, 2011 13:03
shantybeater wrote:In that case I'm definately interested, my next service is probably a few months away though so someone may want to jump in before me? If not I'll happily go first
Hi All,
just posted the 'Free Fix' kit to Shantybeater. If anyone wants to take this project on themselves, he will gladly pass it on to you.
cheers< Soma
soma
Postby RST Driver » Sat 12 Nov, 2011 03:49
Great offer.
Could anyone of you please send me just one of these Viton O-rings? I think I can grind the tool quickly myself but I'm really interested in one of these rings.
Who would ship one to germany?
Best regards,
Phil
RST Driver
Postby soma » Sat 12 Nov, 2011 11:27
Halo aus Australian,
Ich vermuete der Shantybeater koennen Ihnen eine von meinen Viton o-rings schicken. Er wird in dem kommenden Tagen die Pakete von mir bekommen.
Viel spass mit im schrauber Arbeit!....3mm dick und 4mm teif sollte hinhauen.
soma
Postby RST Driver » Sat 12 Nov, 2011 20:43
Good to know. :)
Shantybeater, could you do me the favor?
Best regards,
Phil
RST Driver
Postby Althulas » Mon 14 Nov, 2011 02:05
I'll be PM Shanty to use this after him or the next in line cheers Soma quite generous of you to offer this service.
Althulas
Postby shantybeater » Sun 20 Nov, 2011 17:32
RST Driver wrote:Good to know. :)
Best regards,
Phil
No problem, i'll drop you a PM when I have them
Althulas is next so i'll get the remainder of rings & tool over to him next (minus RST Drivers and mine). I guess PM him if anyone else wants to get next in line?
Thanks again for this Soma, very generous of you..
Postby shantybeater » Mon 21 Nov, 2011 12:12
RST Driver, PM sent
Postby sonic555 » Mon 21 Nov, 2011 22:55
Althulas wrote:I'll be PM Shanty to use this after him or the next in line cheers Soma quite generous of you to offer this service.
Althulas,
PM sent to you, hopefully I can use the kit from you when your done :wink:
Soma, very generous of you :)
sonic555
Postby soma » Tue 22 Nov, 2011 11:32
Althulas,
No Worries...glad to know 'M' owners are taking action on this!! 8-)
soma
Postby RST Driver » Thu 22 Dec, 2011 00:32
Shantybeater, did you send the O-ring to my address?
Best regards,
Phil
RST Driver
Postby Badman gee » Thu 22 Dec, 2011 07:33
shanty,
i have a service soon, can i have an o ring please?
many thanks
mark
Postby shantybeater » Thu 22 Dec, 2011 12:07
RST Driver wrote:Shantybeater, did you send the O-ring to my address?
Best regards,
Phil
I did indeed, has it still not turned up? :s I can send another!
Mark, I can send one over to you as well but you really need the tool to make life easier, there is a bit of a queue now though ! I'd PM althulas and sonic (above)
Postby RST Driver » Thu 22 Dec, 2011 14:07
Not yet. Maybe I have to wait another few days.
But thanks for shipping one o-ring to me. =)
Best regards,
Phil
RST Driver
Postby shantybeater » Thu 22 Dec, 2011 14:39
RST Driver wrote:Not yet. Maybe I have to wait another few days.
Best regards,
Phil
Phil, PM me your address again for confirmation and if it still doesn't appear next week ill send another
Postby RST Driver » Wed 18 Jan, 2012 14:22
Finally got it from James, thanks again for that great offer!
What is the tightening torque for the valve? Anybody knows?
Best regards,
Phil
RST Driver
Postby shantybeater » Sat 21 Jan, 2012 15:18
^^ good question, my car will be going in on tuesday for its InspI+brake/coolant flush so i'll be getting my garage to fit the seal at the same time. When I get it back on wed/thurs I will send the rest onto Mark (althulas)
Postby RST Driver » Mon 06 Feb, 2012 00:23
I torqued it down to something between 20 and 25nm. 20nm were no problem with a standard bit but just below 25nm the bit started to bend the slotted head of the valve.
Something between 25-28nm is just right.
Keep in mind to manufacture a special tool.
Best regards,
Phil
RST Driver
Postby shantybeater » Tue 28 Feb, 2012 22:56
Thanks for the details, I got my specialist to fit the seal with its oil change.
Just a heads up, the seals & tool are on there way to 'althulas' so direct any requests onto him. Thanks again for this Soma, very kind of you to do this especially for free...
Postby soma » Wed 29 Feb, 2012 12:18
Great to hear the tool and rings are making their way around to other M owners! Keep it going and stop those leaking valves gentlemen! :D
soma
Postby swamper » Wed 29 Feb, 2012 17:45
if there any left could i have one please :?:
Postby Althulas » Wed 29 Feb, 2012 23:26
Hi guys just to update James has sent the seals and tool on but I'm away and unable to collect the parcel intill Friday and will contact people who want one of the seals to forward on or who next inline for the tool after I can get my car in for it's oils change and a few jobs including this one.
Mark
Althulas
Re: Free Fix for Constant Pressure Valve
Postby Althulas » Fri 02 Mar, 2012 21:57
Got the items today James Cheers if I've followed the thread correctly Sonic is next in line for the tool and o ring kit. If anyone needs just the o ring can they pm me so I can post them on.
Althulas
Postby John Wilson » Sat 03 Mar, 2012 11:14
Just to say, what a brilliant thread this is. Z owners cooperating together to fix a common problem. Thanks to Soma for the inspiration and generosity for initiating this. This is what the site does best and is what will keep it thriving.
John
John Wilson
Postby Althulas » Wed 14 Mar, 2012 18:14
I got mine done today along side my inspection I and diff and gearbox oil change. There was a small leak from CPV and the o ring was solid like plastic. I believe Sonic is next in line PM sent.
Thanks again Soma my indie was impressed with your generosity and Pingu write up.
Update kit sent out to Sonic 28.03.12, I believe Swamper is next in line after Sonic
Althulas
Postby cemalakcal » Tue 27 Mar, 2012 19:42
PM me if you still have constant pressure valve O rings kit ;)
cemalakcal
Postby soma » Sat 14 Apr, 2012 23:57
HI Sonic,
I hope everything is going well with the tool and rings. Have they been forwarded on to the next person in line? There is a gentleman over at Z3Mcoupe.com who lives in Ireland who would like to get a hold of a ring. I told him to have a look at this thread and make a request.
Keep those ring replacements going!!!
cheers< Soma
soma
Postby pingu » Fri 18 May, 2012 10:32
Info for when the free ones run out:
I have just got some o-rings for my Escort's FIP and they supplied next day for £1.50.
The o-ring for the constant pressure valve is 14.5mmID and 1.5mm cross-section
http://simplybearings.co.uk/shop/p513108/1.5mm+Section+14.5mm+Bore+VITON+Rubber+O-Rings/product_info.html
There is a minimum order quantity of 2 and that will cost you £5.70, but 10 will only cost £6.95.
Postby soma » Sat 19 May, 2012 01:15
Viton is the real deal...that is a great price too :D
Whoever has the tool and rings presently, it would be good to get in touch with the next person in line. cheers< Soma
soma
Postby sonic555 » Wed 23 May, 2012 11:50
soma wrote:HI Sonic,
cheers< Soma
Hi Soma,
Yes I have the kit and will forward to your Irish friend if he wants to give me his details.
I'm not sure who's next so if someone wants to get the kit I'll be happy to forward on.
Many thanks again Soma,
Regards,
Gary
sonic555
Postby soma » Thu 24 May, 2012 05:06
Thanks Gary!
the request from the chap from Belfast over at Z3mcoupe was back in March so I assume he has it sorted.
send it along to whom ever is next in line :D
cheers, Soma
soma
Postby hotrod » Thu 24 May, 2012 07:17
Picked up my roadster last week and would be keen to be added to the list please
Dave
hotrod
Postby soma » Tue 31 Jul, 2012 04:15
Hi Gary,
do you still have the rings and tool...there is another request to fix a valve.
Please give us an update when you get a chance.
cheers< Soma
soma
Postby soma » Fri 17 Aug, 2012 03:36
Does Anyone Know Where the rings and Tool have gone??? :cry:
soma
Postby soma » Sat 18 May, 2013 03:41
Hi All,
Anyone know where the tool and rings have gone? It has been a while so just wondering if those constant pressure values are being looked after.
all the best, Soma
soma
Postby swamper » Sat 18 May, 2013 19:49
i could do with ago myself...
Return to M Roadster and M coupé
