Alternative Roof Proofer / Protector
Post by g8jka »
After using Autoglym's convertible roof kit last year I was never happy with the results achieved. The cleaner is OK but I found the protector to be rubbish as it didn't seem to last long or even bead.
Ages ago I brought some of the autoglym lifeshine range but never got round to using it and having found it in the garage I noticed I had two bottles of Fabric and Upholstery protectant. Reading what this does it is normally used for interior mats, carpets and seats and forms a barrier to protect against any spills so I thought it can't do much harm trying it on the roof.
Anyway here are the results after a quick go with the pressure washer
Quick video
Photo not long after
It was applied about 5 or 6 weeks ago now and I am pretty impressed with the results, it gives great protection when cleaning and also when it rains. It is part of the lifeshine kit, with the letter B on the bottle listed as upholstery and carpet protector or I believe a number 1 on the newer style bottle listed as interior protectant. There is some listed here at the moment on ebay, not a bad price either compared to what others cost.
PCSAM
Re: Alternative Roof Proofer / Protector
Post by PCSAM »
stunning results mate .......... :shock: :lol:
Ragtop
Post by Ragtop »
That looks very impressive. :thumb:
Post by Jonttt »
Try tent proofer, cheap for 5 litres and to be honest you would get nowhere near that much water left on the roof as it literally throws it off ;-)
Just don't get it on the bodywork or glass and let it dry :shock:
z3ddie
Post by z3ddie »
Just done mine with Mequires cleaner and proofer spray - don't bother its rubbish - probably looks worse than when I started and spent and age powerwashing and applying the cleaner and then spraying it off - think I will try boot polish - at least I know that is black!
geminimustang
Post by geminimustang »
I've had great results with the Autoglym at my second attempt.First time around,i skimped a little with the proofing solution,i went over it a couple of weeks later and had really great result.Been done months now,not had to do it again and will definitely buy more when needed.Cheapest place i found was Amazon.
chrisp_1
Post by chrisp_1 »
I did mine with autoglym twice recently and it beads something chronic under the hose-pipe after second application?
That said at £15 a kit it's too expensive to buy again so bought some fabisil (5l for £30 - should last forever) :D
Vic-Z3
Post by Vic-Z3 »
Hi Jonttt
Which Tent Proofer did you use? as there is a few on the market to chose from. As your results
were excellent I will follow suit.
chrisp_1
Post by chrisp_1 »
This is the one you need (as said above :roll: ).
http://www.ebay.co.uk/itm/Grangers-Fabs ... 218wt_1394
Vic-Z3
Post by Vic-Z3 »
Was that the one Jonttt used then .................... :)
Post by Southernboy »
Just ordered some myself....I note that the Audi TT forum has also rave comments about the Fabsil... 8-)
Post by Jonttt »
Vic-Z3 wrote:Was that the one Jonttt used then .................... :)
I just used a generic one from a camping shop c£10 for 5 litres and it works better than any other I've seen :D
lowriderz3
Post by lowriderz3 »
I have reproofed my roof with Fabsyl purchased from Go outdoors £11 seems to be working as water now beads on the roof.
I still have not decided about putting my hardtop for the winter as today the sun has been shining.
Eastsix
  Not specified
Post by Eastsix »
Im looking at a tin of the fabsyl stuff on ebay - stupid question though, how do you apply it? Im used to spraying on the Meguiars hood proofer.
2.8 sadly departed, currently between zeds.....
Post by Del »
Good stuff - I use Fabsil Gold. Simply paint it on with a brush - less mess than a spray.
magicmitch
Post by magicmitch »
hi, new to the forum but not new to the waterproofing saga!!
My Z is 10 years old now and I'm trying to nurse the hood through a couple more seasons!! I've always used the Autoglym stuff but it seems you have to buy this as a "2 pack" type product with the cleaner as well, so I now have loads of spare cleaner. But, I always find it easiet to tip the waterproofer out into a container and apply it with a brush, this way you can really wack it on, and the results have always been excellent!
Vic-Z3
Post by Vic-Z3 »
Two coats of Fabsil, brushed on with a 1" paint brush .......................resulting in no more leaks into boot or cabin areas ........ :D
