Gookah's Z3 2.8 Progress
Post by gookah » Thu 27 Dec, 2012 19:41
Here we go again. ..... Z3 Number 4
This ones my new toy, and to be honest I think all the forthcoming tinkering will be more fun than I got from the fully loaded Z4M I had, 'cos all I could do was polish it and get flashed by other motorists and camera's. :D
This one's a 2.8, and still has enough poke to get me out of shape on occasion... :oops:
The 'M' number plates will go, to be replaced with pressed ones, but they are all I have for now...
So, there's no sport spec, red leather standard seats with no heating... :head: no aircon, and gingercaters all around. But a good base to start with 86,000 on the clock.
A hardtop was included, but the brackets are the homemade version off eBay.
They still work, even though the heated rear window didn't, No cable connections on this version.
Some of you may have seen the first purchase already,
M seats in blue and black, a blue dash, extended leather door cards and extended leather console also in blue leather.
Re: Z3 2.8 Progress Journal
Post by Z3cade » Thu 27 Dec, 2012 20:00
Is it the twin or single vanos gookah?
The M seats were the best mod I did to my last 2.8 :)
Post by TitanTim » Thu 27 Dec, 2012 20:01
Looking good Pete, look forward to following what you do :lol:
('_')Z3
Post by ('_')Z3 » Thu 27 Dec, 2012 20:11
All looks good :D especially with all the bits Santa has brought you this Christmas. Where do you get your pressed plates from?
Post by gookah » Thu 27 Dec, 2012 20:19
Z3cade wrote:Is it the twin or single vanos gookah?
Its an April 2000, so double Vanos M52TU engine, last of the 2.8's
Post by gookah » Thu 27 Dec, 2012 20:21
('_')Z3 wrote:All looks good :D especially with all the bits Santa has brought you this Christmas. Where do you get your pressed plates from?
Last set of pressed plates I got from the show at Santa Pod,
however the next set are most likely an internet trawl...TBC
Post by gookah » Thu 27 Dec, 2012 20:23
TitanTim wrote:Looking good Pete, look forward to following what you do :lol:
Thanks Tim,
I have plenty to do as well......
Santa was extremely generous... :oops:
Post by Z3cade » Thu 27 Dec, 2012 21:08
Looks like that lot will keep you busy!!
The M52TU engine is great, and surprisingly economical!
Have you thought about the 330 inlet manifold conversion? It's quite easy DIY job and all you need is the manifold and adaptor bracket.. Bolt on job £150-200 for parts
But best to get it remapped to get best benefits from it if you do..
Look forward to your progress
Post by gookah » Thu 27 Dec, 2012 21:12
Z3cade wrote:Have you thought about the 330 inlet manifold conversion?
As if......... :wink:
Post by Z3cade » Thu 27 Dec, 2012 21:18
Good man :twisted:
Any plans for wheels?
Post by gookah » Thu 27 Dec, 2012 23:06
Z3cade wrote:Good man :twisted:
yes, indeed
Post by gookah » Fri 28 Dec, 2012 00:00
First hurdle to overcome was the recurring engine light and the erratic idle when cold.
and the cause:
the common split elbow. so for less than a tenner I bought part no 13541435627. Please note it is a superseded part and you do not need the extra hose clip or joint that they advise if yours already has the two adjacent hose clips as shown.
Codes showing were P0170 and P0173 fuel banks 1 and 2.
Until I got the new elbow I kept resetting these to turn of the light.
Since changing the elbow they have not returned and the idle is smooth again.
and the dust in that engine bay.... :bawl:
Post by gookah » Fri 28 Dec, 2012 01:00
So.... the dash was a tricky job to refit, as the 3 bolts under the windscreen (7mm socket size) screw into spring clips that slide about, and you cant move them with the dash in place if they are slightly out.
But other than that, just took a while to strip everything out.
What do you do with the original red console? The replacement one that I bought had the blue extended leather under the handbrake but was the pre-facelift.... :head:
Anyway, I got some blue carbon vinyl and wrapped my red console and swapped over the switch panels. I also wrapped the steering wheel trim.. but I'm not sure.
It may have to go black carbon.
The seats had different connections for the seatbelt pre-tensioners, so I had to solder the new connectors in place. Luckily I had the foresight to get both male and female halves from the breakers, All other connectors were identical, and I kept the airbag module.
All the other wiring was there for the heated seats and they plugged straight in. I had a couple of facelift heated seat switches given to me by my son G8JKA and the relay was already fitted.
Whilst the console was out I moved the roof switch wiring to the front as well..
Seats fitted, windows greased before fitting the new door cards, airbag light reset, (I had to move the car with the seats out..) and everything tested and working fine.
Lovely having heat on base and back again..... God those old seats were cold in a morning.
They need to have the scuffmaster treatment, but for now will suffice as the colour looks darker than Estoril, but thats is what the doorcards and console have written on them and I need to get the match correct.
Anyway here are a few pics of the new interior..
The head unit is next....
Vanne
Post by Vanne » Fri 28 Dec, 2012 04:55
Hi ya Gookah,
Mate extremely interested in your updated console. I also have a 2k z3 but a coupe, mine has the older style console in it with the larger push button switches. I recently bought a 2001 console (like your new one) but was wondering if the connectors at the back of the switches will be plug and play or will I have to get he soldering iron out?
By the way, nice bunch of mods mate ;)
Captain
Post by Captain » Fri 28 Dec, 2012 09:08
Looking good, really like the M seats :D
Post by Brian H » Fri 28 Dec, 2012 09:39
Great read, this brings back fond memories of me doing something similar to the interior of my last car. It totally transforms the feel of the car :thumb:
Santa was certainly good to you, be interested to hear some feedback on the springs you are going to fit. I see Eibach supply 2 different spring types, sport line and pro-kit. Not sure how much difference there is between the two types?
Look forward to the next update.
Post by gookah » Fri 28 Dec, 2012 12:14
Vanne wrote:Hi ya Gookah,
You will need the different switches also, as pre-facelift switches don't fit the facelift console (they are different widths,) but hopefully they are supplied in your new console, however the connectors are also different for the older/newer switches even though they do the same job, I believe your coupe may have the older style wiring loom and connections
Post by gookah » Fri 28 Dec, 2012 12:34
Brian H wrote:Great read, this brings back fond memories of me doing something similar to the interior of my last car. It totally transforms the feel of the car :thumb:
The Sport Line (red springs), IF you can get hold of them, are lower, (as in 45-50mm drop) and firmer and recommended for track cars, The Pro-Kit lower 30mm all round and are more suited for a daily road going car.
I had the Pro-Kit on both my Z4's as well and they improved the looks and handling.
Post by g8jka » Fri 28 Dec, 2012 12:43
gookah wrote:Image
Please lose that ///M badge :head: :roflmao:
Have you fitted that stereo yet? :roll:
Post by Z3cade » Fri 28 Dec, 2012 17:30
Makes such a differents having the M seats in.. Your interior reminds me so much of my 2.8 :( miss it..
Keep up the good work :)
Post by gookah » Fri 28 Dec, 2012 19:24
The head unit and sub are now in, and working a treat, iPhone connected and wiring hidden, Bluetooth handsfree through the speakers with auto mute of the radio, even for directions in maps app.
Head unit controls the iPhone and charges it too.
You can even tailor the colour to the car, The display can be blue/white/green/red and every shade in between. I saw over 30 odd settings, and chose the orange closest to the standard.
Another feature is if the phone rings, the display colour is selectable and the default changes it to flashing blue..
It sounds great with the sub now..
a better pic of the interior, with the hardtop removed..:
and the stainless hoops installed,
These are the homemade hardtop brackets,
I got a facelift HRW switch, and plugged it in, but had to connect into the existing wiring behind the passenger seat. But that works now as well..
also put the seat tilt kit on the drivers (cheapo version)
That will do for today...
Post by Del » Fri 28 Dec, 2012 19:52
Gookah – would you mind me asking whether there is a particular type of carbon fibre sheeting you would recommend for the internal dash trimming. I don't know much about it.
Post by gookah » Fri 28 Dec, 2012 20:05
Just look on eBay for the 3M stuff, its all pretty similar
Post by gookah » Sun 03 Feb, 2013 20:52
Bought some Scuffmaster in Estoril blue:
I also bought a leather repair kit, slid a 'repair patch' underneath the rip, applied the glue, then held it together for 2 mins and left it for an hour.
Cleaned the leather with the cleaner from the repair kit then applied the Scuffmaster by dabbing it on with a sponge.
This was the drivers side, and was after just one coat,
Image Image
I will do another coat tomorrow, then onto the passenger side which is no where near as bad.
a view from afar:
Impressed is not an adequate enough word for how I feel....
Also had a small cigarette burn, and in the repair kit was some leather filler, so applied it and now I will touch up with a marker pen until I get some black Scuffmaster.
('_')Z3
Post by ('_')Z3 » Sun 03 Feb, 2013 21:10
Looking really good :D
My first standard red leather seats I used the German kit (can't quite remember the name :oops: ) and was impressed with that as well, but not cheap!
When I got the ///M seats I decided to get the drivers bolster done professionally which to be honest was the same cost as the German kit and looked even better, £60 I think!
It looks like you've got a great finish though for a first coat
Pierrick
Post by Pierrick » Sun 03 Feb, 2013 23:38
Wow!!! The result on the seat is amazing!! Where did you get the scuff master and the repair kit???
There is a few places on the internet where we can found the scuff master but I'm not sure about the repair kit! Your seat looks very good so if I could do the same on my seat I would be more than pleased!!
Post by gookah » Mon 04 Feb, 2013 12:03
Pierrick wrote:Wow!!! The result on the seat is amazing!! Where did you get the scuff master and the repair kit???
This is the repair kit,:
http://www.ebay.co.uk/itm/130567872335? ... 1497.l2649
and Scuffmaster is available here :
http://www.liquidleather.com/scuffs.htm
Re: Gookah's Z3 2.8 Progress
Post by Z3cade » Mon 04 Feb, 2013 12:35
Looking good Gookah.. Keep up the good work!
Post by gookah » Mon 04 Feb, 2013 19:03
Also tried to get rid of some of the sagginess in the leather with a hot air gun,
this was as much as I dared...
Passenger side now in progress....
Pierrick
Post by Pierrick » Mon 04 Feb, 2013 19:11
Ok thanks. There is a lot in this repair kit! Did you use everything?
I found a very cheap one, I guess you have the same in yours plus other bits...
http://www.ebay.co.uk/itm/Leather-Repai ... 4ab37b142a
And for the colour I found this:
http://www.ebay.co.uk/itm/Scuff-Master- ... 27ce888e24
Which i think is the same as yours but red... i'm just not sure if this the right red for me!
Or this one:
http://www.ebay.co.uk/itm/33-33-100ml-c ... 19d2e2656a
Which seems to be the right colour. (Q2TD Tanin red)
Thanks for your help, i might create a mew post at the right place to not pollute tis one!
Post by Brian H » Mon 04 Feb, 2013 19:40
Great job with the seats, they look to be coming up a real treat. Jobs like these are so satisfying when the results can easily be seen. I would not have thought of a heat gun to tighten the seats :thumb:
Evs87
Post by Evs87 » Wed 06 Feb, 2013 14:19
Gookah,
Where did you get that iphone mount? Does is come with the usb cable attatched? Would you recommend that stereo for use with iPhones?
Post by gookah » Wed 06 Feb, 2013 15:30
Evs87 wrote:Gookah,
EBay:
http://www.ebay.co.uk/itm/Dexim-DCA166- ... 416eb939b7
It has a USB cable attached and this plugs into the back of the head unit to charge/ play music.
The head unit works equally well as a direct usb connection, or bluetooth streaming of the music.
On longer journeys I put the phone in the dock to also charge it, but on short ones I just use the streaming as it sees the phone when I start the car.
Post by gookah » Sun 31 Mar, 2013 21:47
Decided to apply the Scuffmaster to the centre console carbon wrap, ~It matches better than the previous blue and gives it a matt finish.
Also fitted my new illuminated start button:
Pointless gadget I know, but simple things..... :D
Post by gookah » Sun 31 Mar, 2013 21:51
Also had a new roof fitted yesterday, and as the interior was now blue, I decided to copy G8JKA and get a blue one as well:
Post by Z3cade » Sun 31 Mar, 2013 22:30
Looks fantastic pete 8-) Love the blue soft top on silver contrast.. Best colour combo on silver imo
Post by Southernboy » Mon 01 Apr, 2013 07:10
:thumb: LIKE IT !
Post by Badman gee » Mon 01 Apr, 2013 08:10
Turn them to face each other it will look like a mirror
Captain
Post by Captain » Mon 01 Apr, 2013 09:11
Looking good, also really like the colour combo.
Sent from my HTC Desire
PCSAM
Post by PCSAM » Mon 01 Apr, 2013 12:40
can you please stop doing these things to your car :evil: :head: . just when i think i have my car the way i like it . you come along every time with stuff that looks great and suits the car well :head:
now i want more bits i cant afford ..
:D looks great mate , love the hood colour 8-) 8-)
Post by gookah » Mon 01 Apr, 2013 18:26
PCSAM wrote:can you please stop doing these things to your car
Just wait 'til I post the other stuff I still have to do......
Sorry :oops:
Post by gookah » Sun 14 Apr, 2013 11:48
new handbrake handle to match my shiny knob:
Captain
Post by Captain » Sun 14 Apr, 2013 14:26
Is that the storm handbrake handle. Looks good.
Sent from my GT-I8190 using Tapatalk 2
Post by Badman gee » Sun 14 Apr, 2013 15:02
Captain wrote:Is that the storm handbrake handle. Looks good.
Not storm motorwerks.
Post by gookah » Sun 14 Apr, 2013 22:16
Finalised the pager alarm with remote engine start:
Post by gookah » Sun 14 Apr, 2013 22:22
And a remote roof close, which will work from in the house, or up to 100 metres away,
OK it doesn't latch the handles, but if it starts chucking it down, I can remotely shut the roof, while I get my coat.
I just have to get in and clamp up, but now there is no sitting in the rain going through the motions getting soaked..
And I just wanted to see if it could be done. :D
Post by Z3cade » Sun 14 Apr, 2013 22:37
Some great mods there Pete! Well done :wink:
Post by gookah » Sun 14 Apr, 2013 22:41
and lowered today with new Eibachs and front Boge struts.
and a new strut brace:
What a difference in driving....
Next week I might get the summer alloys out..... :D
Post by gookah » Sun 14 Apr, 2013 22:44
and while were at it, I might as well show the induction kit with hose routed through to front bumper lower grille:
Bi11
Post by Bi11 » Sun 14 Apr, 2013 23:29
Blimey, you've had a busy weekend. Looks smart.
