Z3m Roadster
Z3m Roadster
Hello,
I am a newbie to forums and also a newbie to my Z3m.
My car is 1998 Z3m Roadster 19k only had inspection 1.
I took her for a long run Swansea too Pembroke then Pembroke too Devon. She (Sooty) started the run lovely loads of power lovely engine note, but on the leg of the journey from Pembroke to Devon (after the over night stop at Pembroke) she became a bit lumpy a juddery at low revs, and there was a loss of power and a bit of slow throttle response.
she has just had her MOT and a quick once over by the mechanic to check she was sound and he didn't find any problems, the car has been garaged all her life and hasn't left the garage for the last 5/6 years. Before i take her to BMW and give them my life savings to find the problem just wondered if anybody could let me know of anything i need to check or have checked.
Thanks in advance
Chris
Thanks in advance
Chris
Re: Z3m Roadster
Welcome to the Forum
Find yourself a good BMW Independent and have a diagnostic check. The car has been laid up for years, did you have an oil change etc and new fuel ?
Re: Z3m Roadster
This is one of downsides of low mileages in that the car can possibly go with never being serviced as the owner goes by the dash lights rather than rule of thumb timescale. Best to have the oil changed along with brake fluid and coolant every 2 years regardless, problem is with Ms no-one is going to spent that sort of cash when doing a low mileage and just go by the dash lights.
Re: Z3m Roadster
Yes all fresh fuel before the run, there was only a tiny tiny bit in the tank so brimmed her with shell optimax. No oil change though yet, ill get it booked in for a inspection 2 and to run the diagnostics, hopefully find the problem and get it resolved and then be back on top form.
Chris
Chris
Re: Z3m Roadster
Took car to garage 2 plugs had broken down, so new set of plugs and a full service and she was good to go!
Re: Z3m Roadster
Nice, simple, non-serious fix. As you car has very low mileage (and only had an Inspection 1) they were probably the originals
Re: Z3m Roadster
changing the plugs is good fun DIY because you get to use that funny bendy socket attachment thats in your tool box and never get the chance to use .I cant wait to get to the cylinder next to the engine,get my bendy tool out and slide it down the hole "heaven" ,im getting exited thinking about it i think ill order another set of plugs!
Re: Z3m Roadster
glad you found the problem. I was going to suggest plugs until you said it was fixed. I had the same issue recently, however, this is the second set of plugs for me.
Tags
Tags
Re: Z3m Roadster
Another who likes getting his bendy tool outtags wrote:glad you found the problem. I was going to suggest plugs until you said it was fixed. I had the same issue recently, however, this is the second set of plugs for me.
Tags
Re: Z3m Roadster
The plugs where the originals! so they are a few years old now! running a lot smoother, quicker and better on fuel now after the service win win! thanks for info!
hope the weather is nice this weekend now roof down!
Re: Z3m Roadster
I think the ///M prefers Shell vtecS10OTY wrote:so brimmed her with shell optimax.
Re: Z3m Roadster
What's that then? I think you mean V-Power.Boysie wrote:I think the ///M prefers Shell vtec
Re: Z3m Roadster
Ray must be hitting the Turps
Re: Z3m Roadster
Robert T wrote:What's that then? I think you mean V-Power.Boysie wrote:I think the ///M prefers Shell vtec
LOL I dont where that came from
Don't mock your get old one day
Re: Z3m Roadster
Boysie wrote:Robert T wrote:What's that then? I think you mean V-Power.Boysie wrote:I think the ///M prefers Shell vtec
Honda perhaps?
