Z3M Advice on replacement panel filter? K&n? Pipercross etc
Hi all,
Any advice on replacement panel filters? Anybody recommend one they have fitted??
Pipercross or K&N etc??
All seem around £35 on ebay. I always think they are a good investment early on in a car ownership. No need to replace each service, just maintain.
Any advice would be appreciated.
Re: Advice on replacement panel filter? K&n? Pipercross etc
Hello,
Have just ordered a replacement k & n will let you know once has arrived
Re: Z3M Advice on replacement panel filter? K&n? Pipercross
Sweet look forward to it. Who did you buy it from?? Price?
I had a KnN panel filter in my 2.8 zed.. Worked well
...any old piece of foam to soak up the water...you guys don't have warm dry weather, so I don't see the point of expensive filters...I mean..what exactly are you filtering...snow, rain, water, ???
Hello,
I work for a motor cycle company not sure if can write names etc on here.. its in Swansea and just opened a Harley dealership tho so i am ordering it direct from k & N at cost takes a little longer to turn up than off Ebay but save the pennies when i can soon as it turns up i will post too see how it is!
Cheers chris
Cheers chris
From someone who has spent many hours researching induction options and filters for the Z3m (and runs a K&N) stick with OEM. They do just as good a job and are cheap to replace.
ps and don't go down the open filter route as you will just suck in hot air.
If you want a bit of induction noise /slightly free'er revving then look at a Simota for c£250 which as an oil coated cone filter but is such a good fit there is little heat soak.
There are lots of arguments as to whether oil coated filters affect the MAF sensor so I won't go there
For £30 it's got to be a K&N then. If not just for a little more roar!!??
I have replaced the standard filter with a Pipercross filter which is more than satisfactory and it was slightly cheaper than a K and N.
Ive tried the K&N 57i and a replacement Piper Cross Panel filter, I have to recommend the Piper, Its the one I'm currently running
I've had both kn and pc panels before on other cars. Found a deeper sound from the pipercross (which I prefer).
Any other recommendations??
