Lights behind heater controls
z3nomness
Post by z3nomness »
So the lights behind the heater control dials are not working.
I've checked all the fuses, but before I start dissembling the dashboard to have a look has anyone had this before? and if so is there anything in particular I should be looking at??
really having fun being back in the Z3, and driving around grinning like an idiot :)
EDIT:
NEVER MIND, JSUT DID A GOOGLE SEARCH AND FOUND THE ANSWER
DC
Re: Lights behind heater controls
Post by DC »
You might stop grinning soon! I've just done mine, bulbs almost £12 each and the devil of a job to get at.
I found going in from the radio aperture didn't help me much and from the side was best with my large size hands.
Enjoy and keep smiling :)
Dave.
Hopefully Google led you here: http://www.zroadster.net/forum/viewtopi ... =18&t=8878
TR4man
  Z4 coupe 3.0si
Post by TR4man »
DC wrote:from the side was best with my large size hands.
Funnily enough I noticed that my heater light isn't working either!
When entering from the side (does this sound a bit rude?) how do you undo those funny round screws that hold the side panel to the console?
You take gently prise the plastic covers off them and use a philips screwdriver on them. The one in the toolkit is a good size.
Cooper01
Post by Cooper01 »
Hi, don't bother trying to pry off those screw caps cause you might scratch your trim, just jab them with the pointed screwdriver and screw the screws out, then remove the caps. You can re-use the caps or just chuck them out. Southernboy replaced his screws with some hex-head screws which he says looks really good. If your reading this Southernboy post some pix and details where you got the screws eh? :)
If you remove the radio you should be able to get your hands in there and grab the bulbs, but you will need some patience and study where they are first! Failing that, remove the center console. That's a bit of work but not overly difficult but you will have to deal with other electronics and bulbs! Reaching around the sides seems a bit hard on my car, the sides of the console are fixed in the console itself and won't come off. I assume people are talking about the trim in the driver's area which connects behind the side panels and reaching in behind from there? Correct me if I am wrong.
Post by Southernboy »
.... they're actually used torx drive screws... bought them off eBay UK. Unfortunately they only had them in polished steel, so I had them black zinc coated. The nice part of them is the heads.. the torx slot has a small circular pole sticking up in the center of the star shape drive... they look very "high tech" compared to the common phillips drive heads, and with them being matt black, and my trim being black they are pretty much invisible. So, no more screw caps.... similar to these shown in the link below.... :wink:
http://i.ebayimg.com/00/s/MTM4NVgxNjAw/ ... T/$_57.JPG
