Oil filters.
Rafolian
Oil filters.
Post by Rafolian » Wed 11 Feb, 2015 08:40
Hola all!
Have just bought a Mann oil filter for my 2.8 from my local motor factors and remember reading on here about they should come with small O rings? Mine only came with a copper sump plug washer. Do I really need to renew these O rings, and if so can I buy them separately? The filter cost 11 euros.
Cheers.
Re: Oil filters.
Post by Southernboy » Wed 11 Feb, 2015 09:09
....common problem we have here too.... I buy a really good brand of filters (not OEM) ...they only include the large O ring for the cap and a copper washer for the sump...I don't use the copper washer because it's too hard and doesn't adapt to the sump bolt shape like the OEM aluminium washer. The small O ring is available from BMW or a reputable O ring supplier.
Part# 11421744001
Re: Oil filters.
Post by Del » Wed 11 Feb, 2015 10:02
This is odd, (I believe you guys as I have seen other similar posts in the past for the larger engines) because whenever I buy an oil filter in the UK for my 1.9 M44, it has always contained a plastic packet containing all 3 o-rings and a copper sump washer. I typically buy either Mann of Hengst. I suspect there is no need to change the two small o-rings at every oil change though - I would guess that every other one is more than sufficient.
Davejue1
Re: Oil filters.
Post by Davejue1 » Wed 11 Feb, 2015 11:01
I've just purchased a K and N pro series oil filter. Came with the large rubber ring and the small ones as well. :)
Jonco
Re: Oil filters.
Post by Jonco » Wed 11 Feb, 2015 20:13
Del wrote:This is odd, ......... because whenever I buy an oil filter in the UK for my 1.9 M44, it has always contained a plastic packet containing all 3 o-rings and a copper sump washer. I typically buy either Mann of Hengst.
Agree - Mann filters usually include small O rings
Mint
Re: Oil filters.
Post by Mint » Wed 11 Feb, 2015 21:09
Just bought a Mann filter for my 2.2. It came with the large rubber ring and the sump washer but no small 'o' rings.
There are only two products required to make the universe work properly: Duct tape and WD40.
If it moves (and it shouldn’t): Duct tape. If it doesn’t move (and it should): WD40.
Jonco
Re: Oil filters.
Post by Jonco » Wed 11 Feb, 2015 21:13
Mint wrote:Just bought a Mann filter for my 2.2. It came with the large rubber ring and the sump washer but no small 'o' rings.
Sounds like a change in policy - I'm about to order some thro' EuroParts - thanks for info. Will now definitely check beforehand.
Mint
Re: Oil filters.
Post by Mint » Wed 11 Feb, 2015 21:20
Got mine from Carpart4less but I think they are the same as EuroCarParts. Certainly their websites are very very similar with same pricing.
Jonco
Re: Oil filters.
Post by Jonco » Wed 11 Feb, 2015 21:32
Diagram on EuroCarParts does show the small O rings for the 1.9 mann filter - no guarantee they're included though
http://www.eurocarparts.com/ecp/c/BMW_Z ... f81&000231
Mint
Re: Oil filters.
Post by Mint » Wed 11 Feb, 2015 21:36
Re: Oil filters.
Post by Del » Wed 11 Feb, 2015 22:09
This is weird, as I suspected, it seems the aftermarket oil filter makers just provide the full set of O-rings for the 1.9 engines :shrug
Fender2004
Re: Oil filters.
Post by Fender2004 » Thu 12 Feb, 2015 09:58
Bought my oil filter from the dealers, even they don't supply the small O rings with the filter, they have to be ordered separately.
Users browsing this forum: No registered users and 11 guests
