Some nice individual decided to pull out my aerial and this has broke the internal plastic piece so I'm looking for a replacement.
Part number 8375159
Wanted Aerial base.
Re: Wanted Aerial base.
Try Andy - aka Spurs fan in a coupe... he will likely have one for you.
I had the same scenario with mine a couple of years ago and it was like searching for rocking horse s***. I got one from a scrapyard in Wales in the end. If you put the part number in real oem it`s also found on most 3' E36 cars which will give you more scope in your search. Good luck
http://www.realoem.com/bmw/enUS/partxre ... series=E36
Hi I contacted Andy along with posting on here and he has come up with one.Southernboy wrote:Try Andy - aka Spurs fan in a coupe... he will likely have one for you.
Thanks for all suggestions.
Are they easy to fit?
Wouldn't mind having a new one.
Dead easy to fit. There might be something in the knowledge base. Always good to replace grommets if you`re going to do it. Grommets are cheap. New base is serious money though.
http://www.zroadster.net/forum/viewtopic.php?t=8613
Ok, thanku.alec.m wrote:Dead easy to fit. There might be something in the knowledge base. Always good to replace grommets if you`re going to do it. Grommets are cheap. New base is serious money though.
It's the plastic piece that's visible on the outside, just a bit aged.
Look up the part number on http://www.realoem.com/bmw/enUS/select , I think post and pre face lift are different.
I managed to get one from Andy - aka Spurs fan in a coupe.
Great price and service. Thanks Andy
No worries mate, glad it worked for you.freds dad wrote:I managed to get one from Andy - aka Spurs fan in a coupe.
