E46 steering wheel
Devon Z
E46 steering wheel
Post by Devon Z »
When I ordered my Zed in 1999 I loved the brochure car so ordered that spec, it showed the car with the three spoke wheel with the bright silver lower trim to match the console/door trims, lovely! Then I was told part what through the build that it wouldn't come with that wheel, gutted! Well now I want to put that wheel on, I know it's been done so my questions are.
1. I believe my car has a two stage airbag at present? It's a June 99 build.
2. Other than the wheel/airbag/loome what other bits do I need? Do I need the E46 slip ring?
Cheers in advance, good to be back.
I'll post pics when I get my photobucket account working!!
99 2.0 Topaz Individual
Re: E46 steering wheel
Post by bertiejaffa »
do you mean the one where the lowest spoke is split in 2?
Post by Southernboy »
All the Z3's have a similar slip ring. A singe or dual stage airbag is irrelevant - the wiring for the airbag(s) is part of the slip ring. You will just need the preferred Z3 steering wheel and your original slip ring. It is easily removable from your original wheel. (3 small screws).
I assume you're referring to this Z3 steering wheel with the chrome SRS insert at the bottom of the center spoke??
Devon Z
Post by Devon Z »
bertiejaffa wrote:do you mean the one where the lowest spoke is split in 2?
Yes, the standard E46 wheel with the round airbag.
I've got the wheel with trims and airbag loom and airbag but it doesn't look like the slip ring will work from old wheel?
You're referring to this wheel then..
Post by mrscalex »
Is this wheel a standard Z3 fitment on some models, an option on Z3s or is it from another BMW?
Standard early Z3 wheel -circa 1996/7
Devon Z
Post by Devon Z »
Southernboy wrote:You're referring to this wheel then..
That's the one, coloured top trim? never thought about that? Looks good!!
So how did you fit that?
Post by mrscalex »
Strangely I actually prefer the early Z3 wheel with the chrome SRS badge to either the later M Sport Z3 wheel or the E46.
Let's face it. Any factory Z3 steering wheel is not the best part of the car anyway!
The steering wheel is standard Z3.. My car is a 2001 / 3.0.
The red colour trim on it is leather which I stuck onto the top cover.
Post by BladeRunner919 »
Southernboy wrote:The steering wheel is standard Z3.. My car is a 2001 / 3.0.
I don't think it was standard, but was an optional factory-fit sports steering wheel. It's not that common to see on a Z3 - most have a version of the 3 spoke with the solid lower spoke.
I fitted one to my 1st z3, 15 minutes of a job - nice and easy
Devon Z
Post by Devon Z »
bertiejaffa wrote:I fitted one to my 1st z3, 15 minutes of a job - nice and easy
Great! I've checked your jurnal but no details on the steering wheel swop. Did you buy new parts or second hand from another model?
Ha ha- oddly i looked too and I missed it off. Simple 2nd hand off eBay, nothing to change - just fitted it - the only difference is if you ever need to remove it - on the normal wheel there are 2 torx screws holding the airbag in place - on this version there's still 2 holes on the rear of the wheel but you push to release springs to release the airbag.
Honestly, simple job, eBay 2nd hand, 15 mins
