Engine bay paint
Justbrowsing
Engine bay paint
Post by Justbrowsing » Wed 07 Sep, 2016 22:54
Does anyone know the paint name or code for the engine bay on a 2001 Sport.
It looks an off-White colour.
I need to match it after doing some rust prevention work.
Main Drives
Audi Q7 - 2016
Audi TTS Roadster 2016
Re: Engine bay paint
Post by Robert T » Wed 07 Sep, 2016 23:56
What colour is the car?
Post by mrscalex » Thu 08 Sep, 2016 07:07
The label in the engine bay has 2 paint references. The upper is the external colour and the lower is the engine bay. They are normally but not always the same. And invariably the engine bay is not lacquered or metallic.
White Sport is it? Any white Z3 is uncommon. But a facelift Sport is quite a rare beast. I've not seen one before anyhow. And if the engine bay is white and the external colour is something else that's even more unusual. In case it's non standard you may want to take it along to an automotive paint supplier and let them use their tool to analyse the colour.
If I'm being over the top about the rarity/unusual thing I'm sure others will slap me down.
Post by mrscalex » Thu 08 Sep, 2016 07:25
HHmmm, think I've clicked. If your car is silver (just seen your profile) then the engine bay at a stretch may look off white but it will be a pale silver due to being non metallic and unlacquered.
Titanium silver (354 external) normally uses titanium silver (flat as above) in the engine bay. And yes I guess it may look like an off white especially with a layer of grime.
As per previous post look at the lower paint name on the colour plate on the nearside inner wing. You'll also see 354 bottom left, probably 354/7 though I'm not sure what the /7 is.
Post by Deano1712 » Thu 08 Sep, 2016 10:31
You cant buy this paint pre-mixed there is no code for it. Easy option is to go to a paint factors and they can put the colour gun in it. If your car is silver the body paint is a non-metallic flat grey matt finish.
Post by mrscalex » Thu 08 Sep, 2016 10:41
Deano1712 wrote:You cant buy this paint pre-mixed there is no code for it. Easy option is to go to a paint factors and they can put the colour gun in it. If your car is silver the body paint is a non-metallic flat grey matt finish.
Did forget to mention that. And on that basis indeed they may as well put the gun on it rather than just mix up a 354 with no metallic flakes.
Post by peter2b » Thu 08 Sep, 2016 22:04
my 2001 z3 sport has tatanium out and what looks like light gray in the engine bay
Justbrowsing
Post by Justbrowsing » Sat 10 Sep, 2016 07:36
Thanks for the replies, very useful.
Yes, the car is Titan Silver. I'll check codes this morning.
Main Drives
Audi Q7 - 2016
Post by Zed Carer » Sun 11 Sep, 2016 20:23
When I had my boot welds repaired by BMW the bodyshop manager had a moan that it took 4 attempts to mix a match for the boot interior - apparently the original paint was factory use only and was not supplied to dealers. They started by trying the original paint (Titanium) without the laquer but it was totally different. Fortunately they mixed up more than they needed so I got the spare to touch up a few places in the engine bay.
Post by mrscalex » Sun 11 Sep, 2016 22:37
Zed Carer wrote:When I had my boot welds repaired by BMW the bodyshop manager had a moan that it took 4 attempts to mix a match for the boot interior - apparently the original paint was factory use only and was not supplied to dealers. They started by trying the original paint (Titanium) without the laquer but it was totally different. Fortunately they mixed up more than they needed so I got the spare to touch up a few places in the engine bay.
Good to know that. Think I'll go to an automotive paint supplier and get them to make a can up. I need to respray a front panel some time.
Justbrowsing
Post by Justbrowsing » Mon 12 Sep, 2016 20:42
Hi all, engine paint is sorted. Apparently it's Goosewing Grey.
Local paint guy knew it and mixed 3 rattle cans and a touch up pot and it matches perfectly.
Car outer is Titan Silver.
Main Drives
Audi Q7 - 2016
