Z3M side mirrors assemble solution
superhuba
Post by superhuba » Thu 02 Mar, 2017 13:46
Hi !
A was luckky to buy z3m side mirrors. To make ideal paint work i had to disassemble them.
The difference between non M z3 side mirrors is that the M mirrors have solid body, and it is impossible to separate the body from base with out saperating the inner pillar from base... Sorry for the grammar, I'm from Russia, but I hope everything is clear;)))
The pillar is connected to the base by sleeve whith spring which is locked by washer from the other side. And it is almost inposible to disconect the washer and not to destroy it.
So i decided to cut it;)
So now we got separate parts. Body and base can be painted.
But how can we assemble the mirror??
I asked turner to create a thread on the sleeve and to create the nut.
And some spare parts were created;))
Next step is to assemble all parts.
Hope this trick will be useful;)
Cabrioot
  Z1 roadster
Re: Z3M side mirrors assemble solution
Post by Cabrioot » Thu 02 Mar, 2017 15:23
Weldone good solution
Solution with snapring is cheaper .
Dont hessitate to give more nice solutions
superhuba
Post by superhuba » Thu 02 Mar, 2017 19:13
I have some more z3m mirror project and i have to disassemble and assemble them twice a day, so i decidet to use the thread and nut solution. It costed me about 10£ per pair of mirrors
The first
It is my kit which will alloud to upgrade any non M mirror to M;)))
Prototypes;)
deni2s
Post by deni2s » Fri 03 Mar, 2017 14:43
Wow! 3D printed z3m mirrors?!
superhuba
Post by superhuba » Fri 03 Mar, 2017 15:15
deni2s wrote:Wow! 3D printed z3m mirrors?!
Yes;) just made them solid base+body. Will try to install tomorrow
Post by pingu » Fri 03 Mar, 2017 17:46
You can smooth them to a mirror finish using diminishing grades of sandpaper. Then you can paint them. You need to make sure that you use an appropriate material that won't react with the paint. Modern professional paint is water-based, but the stuff from Halfords is still solvent-based.
Excellent idea. You should go into production. There is a market as lots of Z3 owners want ZM mirrors.
Post by BladeRunner919 » Sun 05 Mar, 2017 15:04
If the price is right, I'm definitely interested!
Post by mrscalex » Sun 05 Mar, 2017 16:36
Cracking stuff. Very well done.
MpowerRob
Post by MpowerRob » Sun 12 Mar, 2017 20:22
Same if the price is right I'm in for sure, :thumb: currently got a broken driver mirror base being held together with tape :oops:
Can't justify spending £100 on a new eBay base.
Robo85
Post by Robo85 » Thu 04 Jan, 2018 20:06
Superhuba,
Have you managed to install the mirrors successfully? Would be awesome if you did :)
