Dashboard trim
Hdz3
Dashboard trim
Post by Hdz3 » Sat 29 Apr, 2017 21:10
Hi , can anyone tell me the correct name and part number for the interior plastic trim that sits right below the windscreen that's held in place by three screws, mine has cracked in two places.
Re: Dashboard trim
Post by colb » Sat 29 Apr, 2017 22:25
Put your last 6 digits of your VIN number in oem site and look up the part for your particular model including right colour
Here is mine for a 99 1.9
http://www.realoem.com/bmw/enUS/showpar ... Id=51_4082
OEM site is here
http://www.realoem.com/bmw/enUS/select? ... &archive=1
Re: Dashboard trim
Post by bertiejaffa » Sat 29 Apr, 2017 22:25
check realoem.com - select classic - then Z3 - then your variant and you will find the part number
Hdz3
Re: Dashboard trim
Post by Hdz3 » Sun 30 Apr, 2017 11:12
Many thanks
Hdz3
Re: Dashboard trim
Post by Hdz3 » Sun 30 Apr, 2017 11:29
Checked realoem, found the diagram , can see the part I want but when you scroll down it isn't listed , the caps that cover the fixing screws are , does that mean they are not available .
Fender2004
Re: Dashboard trim
Post by Fender2004 » Sun 30 Apr, 2017 13:05
Normally it does state when items are not available.
Easiest way to find out is to contact your local dealer.
Re: Dashboard trim
Post by spurs fan in a coupe » Sun 30 Apr, 2017 14:26
The part closest to the windscreen with the 3 blanks covering the little bolts (8mm I think) is the main part of the dashboard.
Big job replacing it.
I have a few black dashboards already removed from the car in Woking, Surrey if you need parts.
Hdz3
Re: Dashboard trim
Post by Hdz3 » Sun 30 Apr, 2017 21:19
Oh right, I thought it was just a cover over the windscreen vents, I'll have to have a rethink, thanks
