DSC Warning Lights on
Bumpa
Post by Bumpa » Fri 03 Nov, 2017 09:28
The car is a 2002 2.2 Sport. I have the brake fluid and the DSC lights permanently on, which the handbook tells me is caused by the DSC system. I have taken the car to a local independent workshop that I have used for years and have always found to be excellent in the past. The story so far...
My car has now been in the workshop for eight days and we are no further forward. The code reader pointed to a faulty lateral acceleration sensor, which as you know is under the flooring on the passenger's side of the car. When the guys lifted the flooring they found a swimming pool with the electronic bits submerged. They dried it all out, cleared the codes, but the same error kept coming back, so they bought a new sensor.
This hasn't fixed the fault, and they now wonder if the water has corroded the wiring connectors. So far they haven't been able to find a wiring diagram of those components for my particular car, a 2002 2.2 Sport. Can anyone point me to the correct diagram?
I don't think they know how to proceed. Has anyone here had the same problem? How was it sorted? Answers on a postcard please. How I hate electronics! :(
motco
Re: DSC Warning Lights on
Post by motco » Sat 04 Nov, 2017 09:22
I doubt that this will be a lot of help but I had these symptoms on my 2.2 Sport accompanied by occasional engine misbehaviour. It was the throttle body faulty which sounds bizarre but all these systems are inter-dependent. If the pedal and the throttle position are out of sync and the revs don't correspond to either the processor assumes all sorts of scenarios. If you have been having even occasional throttle response events it may be worth a look. All that being as it may, mine did return fault codes related to the throttle body.
Good luck anyway. If you are anywhere near Amersham (Buckinghamshire) go and see Phil at CPC.
Post by Robert T » Sat 04 Nov, 2017 14:54
Error codes for a specific sensor are normally caused by the sensor emitting implausible values, whether that being due to a sensor fault, wiring fault or something connected to the sensor not generating the right inputs. So, if the car flags up a specific sensor, it is usually something closely related to that sensor which is at fault.
With the acceleration sensors, note that there are two. Make sure they have changed the right one!
From memory, I seem to recall that there is some kind of calibration process that has to be carried out on the new sensor. I don't recall if this needs software, or if it is automatic, requiring the car to be driven. I do know that INPA will show the individual outputs from the sensors, so you can check whether they are working and that the values are within the acceptable range.
Edit: some more info here.
Cheers R
Bumpa
Post by Bumpa » Sat 04 Nov, 2017 17:19
Thanks for those thoughts. I am not close to Amersham, living as I do in Troon, SW Scotland!
The link that Robert sent would be a lot more useful if I could see the pictures. Is there any way to make them appear? I know that Photobucket have screwed up lots of forums - is there a work-around?
Mike
motco
Post by motco » Sun 05 Nov, 2017 09:37
Yes, sorry Mike, I should have checked your profile before I posted!
I seem to recall that there may well be a work-around but I cannot remember what it is. I think it involves the original poster of the images to add some code to the thread they're embedded in.
Post by Gazza » Sun 05 Nov, 2017 11:56
viewtopic.php?f=2&t=45394
Photo bucket fix
Bumpa
Post by Bumpa » Mon 13 Nov, 2017 19:23
Robert said "From memory, I seem to recall that there is some kind of calibration process that has to be carried out on the new sensor. I don't recall if this needs software, or if it is automatic, requiring the car to be driven. I do know that INPA will show the individual outputs from the sensors, so you can check whether they are working and that the values are within the acceptable range."
Spot on Robert. I was discussing the problem with the workshop guy on the phone and I asked him if a BMW agent would be able to get better information out of the car with better equipment. I almost heard the light bulb of an idea spring into his head. He scratched around and found a more sophisticated code reader / scanner and bingo, it told him that the sensor was out of calibration. It registered a sideways movement when the car was stationary. He calibrated it with the scanner and out went the lights -whoopee! :D Now I have to dry out the flooring and find out where the rain gets in.
He then did the MOT and it passed with just one advisory - apparently the RH front brake is very slightly binding. Not enough to make the brake hot, but enough to show as a difference on the rollers. Well, I'll take a look at that once I have it back, which won't be till Wednesday as I can't get down to the garage (11 miles away) until then.
Things are looking up, especially since the Autoguard warranty is going to cover the cost of the new sensor and fitting. Happy days.
Users browsing this forum: lordhelpus and 7 guests
